1 - 9 of 9 Posts
I recently i got an Asus 4830 and it was great(OC'd to ~800/1100), but later the fan started acting up.
Nope, it's not the reference cooler, it's asus's own heatsink with no fanspeed control...
Anyways i started hearing this fairly quiet clicking sound from my pc, so i checked the temps and somehow idle gpu core temps were 10c more than usual. The fan might be a bit crooked, but i doubt that.
It sort of stops clicking and speeds up a bit when i push on the "fan cage". has anyone had this issue?
Efficiencycionado
i love the 1 slot cooler from asus. i wish it was available in my local store. unfortunately, i can only settle with powercolor. just max the fan with those oc
Efficiencycionado
hmm how about changing the fan speed in catalyst, ati overdrive?
Efficiencycionado
Originally Posted by Humanfactor
Wow. I'm suprised people can write, but can you read aswell? First post. Second sentence: no fanspeed control.
I still think i'll rma it.
i did, but i thought it's just in the bios and can be override using softwares. man, that sucks.
I had the same issue with The Asus 4830, where the Fan Bracket ontop of the heatsink began to rattle around after a few days, then after a few days of that i noticed that my system had one day turned itself off while i took some n00bs to skool in 2142!
and with that i felt it was injury to insult and cracked open the case to discover the cooler fan had stopped working! i cranked open CCC and looked at the temp and it was 85 degrees C! which i know is about 10 degrees above normal load running temp!! so i shut down the system as quick as i could and left it alone for a few hours came back and turned it of and kiked CCC in the guts and watch the IDLE TEMP rise to 65 Degerees C with an ambient temp of about 15 Degrees C...this Almost makes me wanna buy an nVIDIA card......did i just say that?!
i'm sending it back for RMA to the vender and hope that this was a one off thing for me as everything else i have owned from Asus has been solid gold and has worked perfectly.
1 - 9 of 9 Posts
