1 - 10 of 10 Posts
A friend of mine had a 7900 GTX, which just stopped working one day, so he took it back to the place where he got it and they RMA'd it for him. He got a Asus 7900 GT to use in the mean while. I have a BFG 7900 GT. Why does he get better FPS than I do? His specs. Opty 165 @ 2.3Ghz(he didn't want to go higher) OCZ DDR400 Platinum Edition 2 GB stick. Enermax Liberty 620 W PSU. Asus A8N5X. THe difference is not by a few FPS, it's by about 30 or more. sometimes less. I really would like to know whats holding my system back... Im running a 2.53 GHZ 3700+ now. with 1 GB ram, had to take 1 GB out or it won't OC. If I get his ram...would that help? or a new mobo? or is this not enough power for PSU? I have no idea whats going on.
he has a DUAL core processor and you have a single core<br>
update your BIOS and see if the 2 RAM stick work<br>
make sure the ram is in the right slots too
Does it really matter? All computers are different bro...
Discussion Starter #4
my BIOS is updated. he even disabled a core, and still better FPS.
Once again, does it REALLY matter?
How exactly did he "disable a core".? Lol<br />
<br />
You can't do that...<br />
<br />
Even if you set affinity for a game to a certain core...the video drivers are still dual core.<br />
<br />
It's all about dual core. Plus he's got an extra GB of ram.<br />
<br />
overclock your GPU, and catch up a bit...
I think he may have meant "hide". It can be done via msconfig under BOOT.INI and checking the /NUMPROC = box and setting it to 1<br />
<br />
Not sure why one would do this...but whatever...
Discussion Starter #9
BIOS. and yes it does matter when your getting 12 FPS.
I'ma call BS on this thread.<br />
<br />
No way your getting 12FPS
1 - 10 of 10 Posts
