1 - 4 of 4 Posts
is very slow on install winxp sp2 or sp3
in windows is slow.
i change the memory and nothing (i have 3x512mb ddr 400 and 1gb ddr400)
and ata to sata disk same results
what to do next??
in windows is slow.
what to do next??
Are you booting up 7,000 things on startup? If so push windowskey+r, type: "msconfig", hit ok, click startup and click of everything but your antivirus suite, note that restarting your computer is optional but recommended. If that doesn't work try a full virus scan. Reset your settings in your bios. Finally if that none of those options work then i would recommend a full reformat and reinstall of windows. I hope this answered your questions
in windows it work very slow so i make a new installation of winxp and its very slow.
the cause of the problem i don´t no
ex: cpu, memory or motherboard????
1 - 4 of 4 Posts
