1 - 11 of 11 Posts
Asus A8N-SLI Premium New non-beta bios available.
[ 1011 ]
1- Update awdflash to v1.17 to avoid the system BIOS being downgraded
2- Fixed failed to boot from Marvell LAN ROM due to IRQ conflict
3- Fixed instant Music function fail issue.
4- Add an option in the Bios to Enable/Disable "Wake up from S1/S3/S4".
5- Fix sometimes asusupdate will show Unknown flash.
6- Improve the compatibility with FX-60 Dualcore CPU.
Reactions: Edge
Originally Posted by Sporadic E
Straight from Asus mi amigo. There was a note about this flash needing the latest chip set drivers so make sure you have those installed. Get them from nVidia.
Es
Thank you my friend! For some reason I could not get into the download section at asus. I tried using Bios 1015 from another thread but Asusupdate said it wasn't a match.
I went to Nvidia and looked at the platform drivers and don't know which one to use, they have nforce4 amd and nforce4 amd/intel x16 I took a gamble and installed the x16 one, is this the right onw? it was v2.85 and the other wasv2.70
Thanks a bunch!
+Rep for you!
Thanks a bunch!
+Rep for you!
Nope wrong drivers. These:
http://www.nvidia.com/object/nforce_..._amd_6.70.html
The ones you grabbed are for the A8N32-SLi and other that have dual 16x SLi. Thanks for rep amigo.
Es
Discussion Starter · #8 ·
The x16 will give you some errors. Uninstall them completely first. Also 1011 is the highest version available for this board currently. Anything above it is for a different board.
Your welcome!
Ooops I guess I used the wrong chipset drivers, I had installed the bios 1011 before using v6.70. It does'nt look like it hurt anything. Should I redo it? Thanks tremendously for the bios, it is in and working Yesss! I was planning on reformating my pc anyways so I will put in the right chipset drivers.
Thanks!
Discussion Starter · #11 ·
You're welcome as well.
1 - 11 of 11 Posts
