Originally Posted by Negotiator is the asus a8n 32x sli deluxe at stock, will it give you better performance than the asus a8n sli premium at stock. even if it is a small increase. also will future graphics cards make full use of the 32x bandwidth? |
Originally Posted by Ropey The general rule of thumb is to add 6 - 8 Degrees C to the core temperature on the ASUS board. Regard: http://www.bleedinedge.com/reviews/a..._temps_05.html R |
Originally Posted by tweako_420 WTH?? How does that mean anything. It doesnt tell how they got the REAL value, doesnt tell what mobos were used, probably didnt use multiple mobos. |
Nevin House - Arctic Silver, Inc.
Originally Posted by Nevin House - Arctic Silver, Inc. One last time... It is a FACT that a temperature measurement taken downstream from the heat source will ALWAYS be lower than the temperature of the heat source due to the thermal resistance between the heat source and the measurement position. So your heatsink measurement MUST be lower than the actual core temperature since it meets these criteria. Not my opinion, basic thermodynamics and accepted scientific fact! The Asus board reports the temperature to be even lower than your heatsink temperature (which we already know is low) therefore it MUST be even further away from the actual core temperature than your heatsink temperature. Not my opinion, basic thermodynamics and math. Due to the facts expressed in the first paragraph, the core temperature will be significantly higher than your heatsink temperature. The Abit board measures the temperatures as being in the range that thermodynamics and math say they should be based on your downstream measurements. (Which we KNOW must be lower than the actual temperature.) So the Abit temperatures are more accurate than the Asus temperatures. Not my opinion, basic thermodynamics and math. So while your call to Asus to revise their measurement calculations are valid, your call to Abit to revise their measurements are in error. This is a fact, not my opinion. Nevin |
Originally Posted by Ropey Did you read the entire article and the forum discussion? If you do so, you will answer your questions. This is the link to the forum discussion that you could have followed in the above link. http://www.bleedinedge.com/forum/sho...8270#post28270 You answered this far to quickly to actually research your own questions and find the answers on the site. Especially regard the work explained by Code:
R |
can anyone tell me how this board(ASus A8n sli premium) compares to the Fatal1ty an8 sli mb? I'm considering buying one of them, but cant make up my mind. |
