ASUS / ASRock / MSI / GIGABYTE (P67 / Z68 / Z77 / Z87 / Z97) motherboard BIOS's with updated Intel RAID OROM
To get full support from the new OROM it's a good idea to redo the array and re-install Windows after you have flashed the updated BIOS.
ASUS Z77 / Z87 / Z97 users will need to use the USB BIOS Flashback feature to flash a mod BIOS, EZ-Flash 2 wont work it will show an error while attempting to flash "Security Verification Failed".
Targeted OROM and Driver per chipset:
P67 / Z68 / Z77 - OROM 12.9.0.2006, Use Driver 12.9.4.1000
Z87 / Z97 - OROM 14.8.2.2397, Use Driver 14.8.9.1053
Garik's OneDrive
--->> Download <<---
Intel RST driver/software download:
Intel RST 12.9.4.1000 Driver
Intel RST 14.8.9.1053 Driver
Note: If your using a P67 / Z68 / Z77 board with Windows 10 you won't be installing a driver, You'll be using the Windows 10 In-Box drivers for RAID.
If you want to modify your own BIOS with the same procedure I use follow this link below. (Click Forum, Upper left)
Modify your own BIOS
If you need a BIOS modified just post what board you have and a download link to that BIOS, Within hours I will post that I added it for you to my OneDrive.
Garik's OneDrive
