1 - 6 of 6 Posts
I remember when......
Anyone have any ideas why flashing from 0706 to 0711 would cause Windows to stop booting?<br />
<br />
The board came with 0602 installed, I used the ASUS Update utility to flash to 0706 last week, and today (ironically) after getting the 4th Windows install on this machine aparrently working....I decided to flash to 0711.<br />
<br />
Well, it flashed fine....BIOS posts and shows 0711.....but after post it just sits at a black screen not doing anything.<br />
<br />
I restarted and reset my boot priority thinking maybe that was it, set my RAID to first, DVD as 2nd, and Floppy to 3rd then disabled the 4th.<br />
<br />
Still, hangs after POST.....I yanked the battery and will try it again in a few hours just in case, but not sure what is going on. This build just seems.....stubborn.<br />
<br />
Anyone have some suggestions? Had this experience?
Discussion Starter #2
Well, I just figured out the problem..........<br />
<br />
<br />
I thought it still saw my array, but when I took a closer look, it was only seeing one drive.<br />
<br />
<br />
I forgot to set my IDE to RAID again, so it wasn't seeing the array........this is my first RAID setup so I call a muligan on that one <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
Will give it to you...LOL...glad you figured it out...<img src="/images/smilies/biggrin.gif" border="0" alt="" title="Big Grin" class="inlineimg" />
I also have been wondering about 0711. I seem to have stability issues when compared to 0614. I also need to stop making concurrent hardware & BIOS changes. One at a time is most likely better.
Maybe you guys should use the "load fail-safe settings" option.
I just did the same update, and had the same problem. I ended up turning off the PC, shutting off the power supply, and waiting a few minutes. When I turned it on, it booted up but said "overclock failed", I just loaded the dafault settings and it worked again. I haven't checked the BIOS revision, but I think the update worked, just the same strange problem of not booting.
1 - 6 of 6 Posts
