Asus Commando overclocking
332 Views 1 Reply 2 Participants Last post by  nckid4u
I was trying to test stability of my overclock (400 X 9) at OCCT and after 4~5min the multi goes to 6 X 400 and keep running..
I disabled C1E & Intel SpeedStep and set the Multi to 9, Why is that?
1 - 2 of 2 Posts
Did you disable eist? After you disable c1e and eist, set your multi to auto. It will default to 9 and some have had issues with setting the multi and the stepping resetting?? I read a few posts about this on another site, but cannot find the link right now.
1 - 2 of 2 Posts
