Asus Commando
354 Views 4 Replies 3 Participants Last post by  Penicilyn
i know there is probably 100 topics about this board already but i just wanted a quick and simple answer, is this board worth $180-$200 australian?
the board is the ASUS Commando
1 - 5 of 5 Posts
Yes the board is worth $180-200 but there are other boards I would get with the money instead.
I'd go with a p5k or a p5n, commando has older p965 chipset.
For a budget (somehow this one is cheap) the DFI INFINITY P965-S DARK motherboard, has solid state capacitors, good chipset and a great overclocker.
http://www.newegg.com/Product/Produc...82E16813136034
Of you want to spend a bit more then go with this GIGABYTE GA-P35-DS3P
http://www.newegg.com/Product/Produc...82E16813128047
1 - 5 of 5 Posts
