When I had the 580s on air, they would idle at 40c-45c or so, and max temp at 70c, at stock.
But it was with 3 cards, so one card should give a bit lower temps.
Take note that case cooling has a lot to do with GPU temps.
If your case isn't GPU friendly regarding temps, its going to be hot.
With a better case, you can drop temps by up to 20c at load.
