What do I suppose to be seeing here?Originally Posted by kan3;13121008
Ok I think I found a solution for it. You have to disable the overdrive option from menu.
Use this image, move it sideways see if you see any ghosting.
Disable overdrive? Isn't that meant to reduce ghosting?Originally Posted by kan3;13121008
Yes Asus monitors come with OD enabled.Disable overdrive? Isn't that meant to reduce ghosting?
