1 - 1 of 1 Posts
Hi,
Just wondering, unsure as to what the feature is that im thinking of however, can you disable the temp target via a bios update to remove the gpu fluctuation with clock speeds etc.
Again im not sure what the feature is called but I noticed in some games my gpu will only use the default clock speed meaning that its not using full power which in turn lowers my likely fps count.
Any ideas
1 - 1 of 1 Posts
