So I contacted Asus Live Support regarding what I'm going through in this thread: http://www.overclock.net/amd-cpus/98...ghz-1090t.html
Just skip to the 4th/5th page and you'll understand what's going on.
Anyway here was our conversation:
You're now talking to Sonny from 'Motherboard ' The topic is : Safeguard?
Sonny> Thank you for contacting Asus Motherboard and Graphic Card support. My name is Sonny, how can I help you?
Luke> Hi before I tell you my problem, here are my specifications: AMD Phenom II X6 1090T 4.1GHz (249 x 16.5) 1.4 CPU voltage -> LLC Enabled -> Voltage rises to 1.467 -1.488 under load. 1.3 CPU-NB voltage NB Frequency @ 2980MHz LLC Disabled for CPU-NB M4A88TD-V EVO Motherboard Adata DDR3 1600 @ 1666mhz 9-9-9-24-33 1.71v Antec EA650 (650W) Cool N' Quiet/C1E/Turbo Core disabled The thing I'm wondering is, when I start stress testing this while monitoring everything I notice that my CPU speed will drop to 2.3Ghz for a couple of seconds and then rise back to 4.1GHz. Is there some built in safeguard in this Asus motherboard or something?
Luke> Oh that makes it hard to read :/ It didn't space it out, sorry.
Sonny> its ok how can i help ypou
Luke> Basically,
Sonny> ooverclocking your system?
Luke> Yes.
Luke> But It randomly jumps down to 2.3GHz for a short period of time(seconds)
Sonny> ok we wont be able to help with the overclocking or troubleshoot the overclocking
Luke> I'm not worried about that. I'm asking you a question about the ASUS motherboard.
Luke> Does it have a built in safeguard that would cause it to drop CPU speed?
Luke> I've read something about OCP - Over current protection.
Sonny> no there isnt
Luke> So you're telling me there is nothing on this motherboard related to OCP? I'm aware that a lot of ASUS motherboards carry this feature, but it's not something you can enable/disable.
Sonny> thats for the power on the board
Luke> So can I or can I not disable this?
Sonny> no
Luke> Ok. Thanks.
I just gave up at the end. He wasn't getting me anywhere nor answering my questions decently.
Luke> Basically,
Luke> Yes.
Sonny> no
Luke> Ok. Thanks.
