You can either use the MB cd(original bios) or a usb drive(formatted to fat32).(latest bios)
Instructions below.
Good luck
Gyro
Instructions below.
Good luck
Gyro
Ok Thanks will try that now.Originally Posted by Gyro;13027101
Yes this is for Asus crashfree
It should be an automatic recovery,with no input from you.You may not be able to see anything till it has recovered and rebooted.
The usb option is your best bet.
Gyro
