Hey guys! Can you please comment on the built in sound card on Maximus V GENE board? Thing is that I bought the mobo and put it in Silverstone TJ08-E. The space is tight so I am struggling whether I should move Xonar DX from my older build...
I know that it's a Realtek chip which was never awesome but maybe things have changed since last Maximus IV GENE-Z? My main concern is sound quality but I also notice that the software is quite annoying too. I have 3 or 4 different programs to control sound settings / effects... which are:
Realtek HD Audio Manager with ASUS logo
Sound Blaster Panel (which takes 10 clicks to pop from taskbar) allows access to:
The only somewhat useful thing here for me is Crystalizer. Makes my electro/dubstep music sound better
ASUS Xonar DX software is not perfect either but still there is only one control panel with a few effects.
So dunno, guys, plz help to decide! Thanks!
- THX TruStudio (Surround, Cristalizer, Smart Volume and Dialog Plus effects)
- Sound Blaster Console (useless EAX effect & EQ which I dunno how to use anyway)
- Creative Music Server (which allows to stream ur music to other devices on network from itunes (or so it says))
