Asus motherboard
1482 Views 2 Replies 2 Participants Last post by  ENTERPRISE
Hey there guys can one of you find me the specs of this board ..its called Asus p4sd-la..thanks guys
I am finding it hard to find this motherboard anywhere..even on the asus site...The chipset it uses is an intel 865p
1 - 3 of 3 Posts
CPU Socket 478
Intel Pentium 4 Northwood/Prescott
New power design for up to 3.2+ GHz
Chipset Intel 848P (Breeds Hill)
MCH with Intel ICH5
Supports DDR 266/333/400 SDRAM
Supports Ultra DMA 66/100 IDE devices
Supports Ultra DMA 150 Serial ATA device
Front Side Bus (FSB) 800/533/400 MHz
System Memory Two 184-pin DDR DIMM sockets
Up to 2GB memory (the PC manufacturer's recommended maximum memory may differ)
Non-ECC 2.5V DDR SDRAM
Register DIMM not supported
Expansion Slots One AGP 8X/4x slot
Three PCI slots
VGA Integrated 3D graphics controller
In Springdale chipset
Serial ATA Intel ICH5 supports two UltraDMA/150 SATA connectors
Onboard IDE Intel ICH5 embedded Dual channel Bus Master ports supports UltraDMA 100/66 connectors, PIO Mode 3/4, and hot swap function
Intel ICH5 embedded Serial ATA port support to Ultra DMA 150 and hot swap function
ATAPI IDE DVD-ROM, CD-ROM, CD-R, CD-RW, AND LS-120 support
Onboard Audio RealTek ALC650 6-channel audio CODEC subsystem
AC'97 2.2 compliant
Onboard LAN Realtek 8101L LAN PHY (Physical Layer Protocol)
10/100 Mbps Fast Ethernet controller
Special Features Power Loss Restart
ASUS EZ Flash
Rear panel I/O One parallel port
One serial port
One PS/2 keyboard
One PS/2 mouse port
One RJ-45 port
Up to 4 USB 2.0 / USB 1.1 ports (two connectors)
One IEEE 1394 port
Audio line-in, line-out, and microphone ports (one each)
Internal I/O Four USB 2.0 ports (two connector)
One IEEE 1394 connector
CPU/chassis fan connectors
20-pin 4-pin ATX 12V power connectors
S/PDIF connector
Speaker out connector
CD/AUX audio connector
Front headphone connector
BIOS Features 4Mb Flash ROM
AMI BIOS with Enhanced ACPI, PnP, DMI2.0, Green features
Industry Standard USB 2.0/1.1
PCI 2.2
Manageability WfM 2.0
DMI 2.0
WOL/WOR by PME
Form Factor Micro-ATX form factor
9.6 inches x 9.6 inches (24.5 cm x 24.5 cm)
Reactions: 3
Wow cheers for that mate..lol cpu-z said it had the 865p chipset ..owel thanks mate
1 - 3 of 3 Posts
