Asus onboard fan controller
1245 Views 6 Replies 3 Participants Last post by  nukefission
So I heard that my Motherboard has an onboard fan controller
Its the fan profile things in bios?Q-FAN < hasn`t really worked maybe needs software
I use that asus software to control fans?
sig rig isnt here so I cant test
1 - 7 of 7 Posts
Try ASUS AI Suite. Has a nice fan controller for Crosshair IV mobo(CPU fan and Chasis fans). May be good for your mobo too.
ok Thx
There was another one with a gray and green theme also by asus
There is cpu Q-fan and system Q-fan.Enable both.
If you want to set what temps it ramps up/down at choose manual.
If you want it to automatically ramp up/down with temps choose standard.
Gyro
Originally Posted by nukefission
ok Thx
PC Probe? Thats for monitoring(fan speed , voltages , temps)
AI Suite does what Gyro suggested, but under Windows.
AI suite/Asus fan expert can be found on the support cd.
Gyro
yeah it was pc probe
I`l try AI suite
It came on my dvd also.
Set Q fan to normal in both bios and system
then fiddle around in AI suite
1 - 7 of 7 Posts
