ASUS P4P800S-X overclock and onboard sound not work
2457 Views 11 Replies 5 Participants Last post by  kryster
I have a Asus P4P800S-X (http://www.asus.com/products/mb/sock...x/overview.htm) motherboard, with the 1005A bios (newest)
I finish install everything, drive(all newest), software(updated) and games(patched), etc ..
everything work fine ..
and now, I overclock it .
I go to bios, and go for 30% auto overclock, it is a P4 2.4A and it run @3.11 ,
I play some games, and it very smooth.
but only 1 problem, the Soundmax Panel can't find the sound device, I have no sound with it after overclock, I installed the SoundMAX Audio logo driver Version 5.12.01.3665 from asus (http://www.asus.com.tw/support/downl...00S-X&Type=All) also the chipset drive .
I don't know why once it overclock, it can't find the sound device , I tired all 10% 20% 30% and manual 166mhz for overclock, and all the rest is Auto .
I change the clock speed to normal , and the sound device is back and have sound, but once I overclock, it disappear ... so, anyone know how to fix it ?
and if this can't fix, what motherboard will be good for overclock that around 100$cad .
thanks you very much .
1 - 12 of 12 Posts
welcome to the forum!!!!!!!!!!!
what psu do you have???
PSU ? .. not sure what is it , but this is my system info , and it is no sound device, now running at 2.98mhz with 166X18 . and it will come back when I change clock speed to normal ... errr ..
System Information
Time of this report: 11/9/2004, 16:56:58
Machine name: C12
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 1 (2600.xpsp2_gdr.040517-1325)
Language: Chinese (Regional Setting: English)
System Manufacturer: To Be Filled By O.E.M.
System Model: To Be Filled By O.E.M.
BIOS: BIOS Date: 09/25/04 18:38:39 Ver: 08.00.09
Processor: Intel(R) Pentium(R) 4 CPU 2.40GHz, ~3.0GHz
Memory: 512MB RAM
Page File: 214MB used, 1035MB available
Windows Dir: C:\\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.0001.0904 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No sound card was found. If one is expected, you should install a sound driver provided by the hardware manufacturer.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce FX 5600XT
Manufacturer: NVIDIA
Chip type: GeForce FX 5600XT
DAC type: Integrated RAMDAC
Device Key: Enum\\PCI\\VEN_10DE&DEV_0314&SUBSYS_00000000&REV_A 1
Display Memory: 128.0 MB
Current Mode: 1024 x 768 (16 bit) (60Hz)
Monitor: Monitor Max Res:
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.6693 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 10/29/2004 16:50:00, 3736704 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: Mini VDD: nv4_mini.sys
Mini VDD Date: 10/29/2004 16:50:00, 2826944 bytes
Device Identifier: {D7B71E3E-4054-11CF-9579-0A2000C2CB35}
Vendor ID: 0x10DE
Device ID: 0x0314
SubSys ID: 0x00000000
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D
Deinterlace Caps: {212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC722-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{212DC723-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_MedianFiltering
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description:
Default Sound Playback: No
Default Voice Playback: No
Hardware ID:
Manufacturer ID:
Product ID:
Type:
Driver Name:
Driver Version:
Driver Attributes:
WHQL Logo'd:
Date and Size:
Other Files:
Driver Provider:
HW Accel Level: Emulation Only
Cap Flags: 0x0
Min/Max Sample Rate: 0, 0
Static/Strm HW Mix Bufs: 0, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
DirectMusic
DLS Path: C:\\WINDOWS\\SYSTEM32\\drivers\\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Registry: OK
DirectInput Devices
Device Name: Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Controller ID: n/a
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x24D4
| Matching Device ID: usb\
oot_hub
| Service: usbhub
| Driver: usbhub.sys, 7/3/2003 17:52:58, 53120 bytes
| Driver: usbd.sys, 9/5/2001 13:00:00, 4736 bytes
Gameport Devices
PS/2 Devices
+ | Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 9/9/2002 00:44:54, 46080 bytes
| Driver: kbdclass.sys, 9/9/2002 00:46:14, 22144 bytes
+ | Matching Device ID: root\
dp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 9/9/2002 15:54:04, 38024 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 9/9/2002 01:05:44, 20736 bytes
dp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.0000.0900)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.0001.0904)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.0000.0900)
DirectPlay Voice Wizard Tests: Full Duplex: , Half Duplex: , Mic:
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 IPX Service Provider: IPX Adapter 1 - (00000000,00A0C9A264F0)
DirectPlay8 IPX Service Provider: IPX Adapter 2 - (00000000,00112FA9FC44)
DirectPlay8 TCP/IP Service Provider: DirectPlay8 TCP/IP Service Provider:
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 13.4 GB
Total Space: 20.0 GB
File System: NTFS
Model: WDC WD800JB-00DUA3
Drive: D:
Free Space: 4.6 GB
Total Space: 50.3 GB
File System: FAT32
Drive: E:
Free Space: 1.3 GB
Total Space: 6.0 GB
File System: FAT32
Drive: F:
Free Space: 3.1 GB
Total Space: 29.3 GB
File System: FAT32
Model: Maxtor 6E030L0
Drive: G:
Model: HL-DT-ST DVDRAM GSA-4082B
Driver: c:\\windows\\system32\\drivers\\cdrom.sys, 5.01.2600.1106 (English), 8/28/2002 10:27:56, 47488 bytes
Drive: H:
Model: Generic DVD-ROM SCSI CdRom Device
Drive: I:
System Devices
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to AGP Controller - 2571
Device ID: PCI\\VEN_8086&DEV_2571&SUBSYS_00000000&REV_02\\3&2 67A616A&0&08
Driver: C:\\WINDOWS\\System32\\DRIVERS\\AGP440.SYS, 5.01.2600.0000 (English), 8/17/2001 13:58:00, 25472 bytes
Name: Intel(R) 82865G/PE/P/GV/82848P Processor to I/O Controller - 2570
Device ID: PCI\\VEN_8086&DEV_2570&SUBSYS_00000000&REV_02\\3&2 67A616A&0&00
Driver: n/a
Name: Intel(R) 82801EB USB Universal Host Controller - 24DE
Device ID: PCI\\VEN_8086&DEV_24DE&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&EB
Driver: C:\\WINDOWS\\system32\\drivers\\usbuhci.sys, 5.01.2600.1243 (English), 7/3/2003 17:51:46, 19328 bytes
Driver: C:\\WINDOWS\\system32\\drivers\\usbport.sys, 5.01.2600.1243 (English), 7/3/2003 17:49:30, 138752 bytes
Driver: C:\\WINDOWS\\system32\\drivers\\usbhub.sys, 5.01.2600.1243 (English), 7/3/2003 17:52:58, 53120 bytes
Driver: C:\\WINDOWS\\System32\\usbui.dll, 5.01.2600.0000 (Chinese), 8/31/2001 18:09:56, 67072 bytes
Name: Standard Enhanced PCI to USB Host Controller
Device ID: PCI\\VEN_8086&DEV_24DD&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&EF
Driver: C:\\WINDOWS\\system32\\drivers\\usbehci.sys, 5.01.2600.1243 (English), 7/3/2003 17:50:46, 25216 bytes
Driver: C:\\WINDOWS\\System32\\hccoin.dll, 5.01.2600.1243 (English), 7/3/2003 17:50:12, 5632 bytes
Name: Intel(R) 82801EB Ultra ATA Storage Controllers
Device ID: PCI\\VEN_8086&DEV_24DB&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&F9
Driver: C:\\WINDOWS\\System32\\DRIVERS\\pciide.sys, 5.01.2600.0000 (Chinese), 8/31/2001 17:36:18, 3328 bytes
Driver: C:\\WINDOWS\\System32\\DRIVERS\\pciidex.sys, 5.01.2600.1106 (English), 8/29/2002 01:27:48, 23680 bytes
Driver: C:\\WINDOWS\\System32\\DRIVERS\\atapi.sys, 8/29/2002 01:27:50, 86912 bytes
Name: Intel(R) 82801EB USB Universal Host Controller - 24D7
Device ID: PCI\\VEN_8086&DEV_24D7&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&EA
Name: Intel(R) 82801EB USB Universal Host Controller - 24D4
Device ID: PCI\\VEN_8086&DEV_24D4&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&E9
Name: Intel(R) 82801EB USB Universal Host Controller - 24D2
Device ID: PCI\\VEN_8086&DEV_24D2&SUBSYS_80A61043&REV_02\\3&2 67A616A&0&E8
Name: Intel(R) 82801EB LPC Interface Controller - 24D0
Device ID: PCI\\VEN_8086&DEV_24D0&SUBSYS_00000000&REV_02\\3&2 67A616A&0&F8
Driver: C:\\WINDOWS\\System32\\DRIVERS\\isapnp.sys, 5.01.2600.0000 (Chinese), 8/31/2001 17:14:28, 35840 bytes
Name: Intel(R) 82801EB PCI Bridge - 244E
Device ID: PCI\\VEN_8086&DEV_244E&SUBSYS_00000000&REV_C2\\3&2 67A616A&0&F0
Driver: C:\\WINDOWS\\System32\\DRIVERS\\pci.sys, 5.01.2600.1106 (Chinese), 9/9/2002 15:36:24, 61824 bytes
Name: Intel(R) PRO/100+ Management Adapter
Device ID: PCI\\VEN_8086&DEV_1229&SUBSYS_000A8086&REV_05\\4&2 E98101C&0&48F0
Driver: C:\\WINDOWS\\System32\\DRIVERS\\e100b325.sys, 7.01.0008.0000 (English), 10/28/2003 12:09:54, 153088 bytes
Driver: C:\\WINDOWS\\System32\\Prounstl.exe, 7.00.0005.0000 (English), 3/3/2003 15:26:52, 118784 bytes
Driver: C:\\WINDOWS\\System32\\e100b325.din, 6/27/2002 05:53:38, 5110 bytes
Driver: C:\\WINDOWS\\System32\\IntelNic.dll, 2.05.0001.0000 (English), 7/28/2003 05:55:38, 24064 bytes
Driver: C:\\WINDOWS\\System32\\e100bmsg.dll, 2/3/2003 05:26:18, 12288 bytes
Name: Realtek RTL8139/810x Family Fast Ethernet NIC
Device ID: PCI\\VEN_10EC&DEV_8139&SUBSYS_80261043&REV_10\\4&2 E98101C&0&28F0
Driver: C:\\WINDOWS\\System32\\DRIVERS\\R8139n51.sys, 5.505.1004.2002 (English), 7/31/2003 22:18:50, 46976 bytes
Name: NVIDIA GeForce FX 5600XT
Device ID: PCI\\VEN_10DE&DEV_0314&SUBSYS_00000000&REV_A1\\4&3 8B71F77&0&0008
v4_mini.sys, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 2826944 bytes
vsvc32.exe, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 127043 bytes
vcod.dll, 1.00.0000.0015 (English), 10/29/2004 16:50:00, 32256 bytes
vcodins.dll, 1.00.0000.0015 (English), 10/29/2004 16:50:00, 32256 bytes
v4_disp.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 3736704 bytes
voglnt.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 5271552 bytes
vcpl.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 4620288 bytes
vmctray.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 86016 bytes
vwddi.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 81920 bytes
vnt4cpl.dll, 6.14.0010.6693 (English), 10/29/2004 16:50:00, 245760 bytes
Driver: C:\\WINDOWS\\help\
vcpl.hlp, 10/29/2004 16:50:00, 161839 bytes
vwcplen.hlp, 10/29/2004 16:50:00, 55256 bytes
Name: D346PRT SCSI Controller
Device ID: PCI\\D346PRT\\0000
Driver: n/a
DirectX Components
ddraw.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 292864 bytes
ddrawex.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 24064 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 10496 bytes
d3d8.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 1201152 bytes
d3d8thk.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 8192 bytes
d3d9.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 1703936 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 436224 bytes
d3dim700.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 797184 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 Chinese Final Retail 9/5/2001 13:00:00 33040 bytes
dplayx.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 230400 bytes
dpmodemx.dll: 5.03.0000.0900 Chinese Final Retail 12/12/2002 00:14:32 77824 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 9/5/2001 13:00:00 42768 bytes
dpwsockx.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 79360 bytes
dplaysvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 28160 bytes
dpnsvr.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 16896 bytes
dpnet.dll: 5.03.0000.0900 Chinese Final Retail 12/12/2002 00:14:32 723968 bytes
dpnlobby.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpnaddr.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 3072 bytes
dpvoice.dll: 5.03.0000.0900 Chinese Final Retail 12/12/2002 00:14:32 381952 bytes
dpvsetup.exe: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 80896 bytes
dpvvox.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 112128 bytes
dpvacm.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 19968 bytes
dpnhpast.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 32768 bytes
dpnhupnp.dll: 5.03.0000.0901 English Final Retail 3/24/2003 09:00:02 68096 bytes
dpserial.dll: 5.00.2134.0001 Chinese Final Retail 9/5/2001 13:00:00 53520 bytes
dinput.dll: 5.01.2600.1106 Chinese Final Retail 9/9/2002 00:53:14 141312 bytes
dinput8.dll: 5.01.2600.1106 Chinese Final Retail 9/9/2002 00:53:14 158208 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 9/5/2001 13:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 Chinese Final Retail 9/5/2001 13:00:00 394240 bytes
joy.cpl: 5.01.2600.1106 Chinese Final Retail 9/9/2002 00:53:58 62976 bytes
gcdef.dll: 5.01.2600.0000 Chinese Final Retail 9/5/2001 13:00:00 76800 bytes
pid.dll: 5.01.2600.1106 English Final Retail 9/9/2002 01:05:44 31744 bytes
dsound.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 381952 bytes
dsound3d.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 1294336 bytes
dswave.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18432 bytes
dsdmo.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 186880 bytes
dsdmoprp.dll: 5.03.0000.0900 Chinese Final Retail 12/12/2002 00:14:32 491520 bytes
dmusic.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 122880 bytes
dmband.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 27136 bytes
dmcompos.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 58368 bytes
dmime.dll: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 181248 bytes
dmloader.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 33280 bytes
dmstyle.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 98816 bytes
dmsynth.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 100864 bytes
dmscript.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 76800 bytes
system.dll: 1.01.4322.2032 English Final Retail 11/13/2004 23:25:29 1224704 bytes
dx7vb.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 602624 bytes
dx8vb.dll: 5.03.0001.0902 English Final Retail 5/30/2003 09:00:02 1189888 bytes
dxdiagn.dll: 5.03.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 1769472 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 9/5/2001 13:00:00 924432 bytes
mfc42.dll: 6.00.8665.0000 English Beta Retail 9/5/2001 13:00:00 995383 bytes
wsock32.dll: 5.01.2600.0000 Chinese Final Retail 9/5/2001 13:00:00 27648 bytes
amstream.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 64512 bytes
devenum.dll: 6.05.0001.0902 Chinese Final Retail 5/30/2003 09:00:02 132608 bytes
dxmasf.dll: 6.04.0009.1125 Chinese Final Retail 9/9/2002 00:53:14 498205 bytes
mciqtz32.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 34304 bytes
mpg2splt.ax: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 136192 bytes
msdmo.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 13312 bytes
encapi.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 18944 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 9/22/2004 18:46:02 221184 bytes
qcap.dll: 6.05.0001.0900 Chinese Final Retail 12/12/2002 00:14:32 257024 bytes
qdv.dll: 6.05.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 316928 bytes
qdvd.dll: 6.05.0001.0904 Chinese Final Retail 7/9/2004 04:27:28 470528 bytes
qedit.dll: 6.05.0001.0900 Chinese Final Retail 12/12/2002 00:14:32 1798144 bytes
qedwipes.dll: 6.05.0001.0900 English Final Retail 12/12/2002 00:14:32 733184 bytes
quartz.dll: 6.05.0001.0902 Chinese Final Retail 5/30/2003 09:00:02 1962496 bytes
strmdll.dll: 4.01.0000.3928 Chinese Final Retail 9/9/2002 00:53:40 251904 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 11/14/2002 13:00:24 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 11/14/2002 13:00:24 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 11/14/2002 13:00:26 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 11/14/2002 13:00:26 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 11/14/2002 13:00:28 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 11/14/2002 13:00:30 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 11/14/2002 13:00:30 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 11/14/2002 13:00:32 154624 bytes
mswebdvd.dll: 6.05.0001.0900 Chinese Final Retail 12/12/2002 00:14:32 324096 bytes
ks.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 130304 bytes
ksproxy.ax: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 117248 bytes
ksuser.dll: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
stream.sys: 5.03.0001.0904 English Final Retail 7/9/2004 04:27:28 48512 bytes
mspclock.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5248 bytes
mspqm.sys: 5.01.2600.0000 English Final Retail 8/23/2001 05:00:00 4608 bytes
mskssrv.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 7424 bytes
swenum.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 4096 bytes
mstee.sys: 5.03.0000.0900 English Final Retail 12/12/2002 00:14:32 5504 bytes
bdaplgin.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
bdasup.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 11392 bytes
msdvbnp.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 52224 bytes
psisdecd.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 354816 bytes
psisrndr.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:40 30208 bytes
ipsink.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 14848 bytes
mpeg2data.ax: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 57856 bytes
ndisip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 10112 bytes
mpe.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 15104 bytes
streamip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 14976 bytes
msvidctl.dll: 6.05.0001.0900 English Final Retail 7/9/2004 04:26:38 1230336 bytes
slip.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 10880 bytes
nabtsfec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 83968 bytes
ccdecode.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16384 bytes
vbisurf.ax: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 27648 bytes
msyuv.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:38 16896 bytes
kstvtune.ax: 5.03.0001.0904 Chinese Final Retail 7/19/2004 16:19:30 285696 bytes
ksxbar.ax: 5.03.0001.0902 English Final Retail 7/9/2004 04:26:38 39424 bytes
kswdmcap.ax: 5.03.0000.0900 Chinese Final Retail 7/9/2004 04:26:40 226304 bytes
wstcodec.sys: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 18688 bytes
wstdecod.dll: 5.03.0000.0900 English Final Retail 7/9/2004 04:26:40 47104 bytes
msdv.sys: 5.01.2600.0000 English Final Retail 7/9/2004 04:26:38 52096 bytes
It sounds just like you do not have you AGP/PCI frequencies locked on 66/33Mhz. the reason you loose your sound when overclocking is the PCI bus is increasing synchronous with the FSB which makes it unstable when it gets to a certain value.
put your system specs in your profile located under quick links then click on edit profile
yes sir .
Also you might look into a BIOS update, they might have fixed that issue.
ohoh , thanks archer_456 , it work now .
so, whatever I overclock on the cpu, I must lock the agp/pci on 66/33mhz ? .
yeah, did it before , it is I didn't lock the agp/pci , hehe
thanks for the reply tho.
why post the same thread twice?
why u ask ?
ur purpose to asking this is ?
u just interesting or ? (nothing interesting)
u trying to picking on me or ? (why ?)
u trying to start a war or ? (why?)
u are very free and just bull**** around or ? ..
well , why u asking ? ...
1 - 12 of 12 Posts
