1 - 3 of 3 Posts
Hi all,<br />
<br />
The following 3330 MHz. OC seems to be the most stable so far with my system on air.<br />
<br />
Do you guy's feel that it will be worth investing the money on water cooling and do you think that I will see much of a performance gain from it?<br />
<br />
I have been able to OC this system to 3800 MHz. on air, but it is not stable and the temps are too high.
I remember when......
What are your load temps? Idle temps are not very usefull.<br />
<br />
As to whether water cooling is "worth it", that's a question only you can answer. It is more expensive (if you want anything that is better than a high end air cooler anyway) and it does require more caerful assembly and maintence.......<br />
<br />
You may want to simply buy a much better heatsink if you're looking for just a little more speed, or if your current load temps are too high already.<br />
<br />
Personally, I think water is worth it not just for the performance but for the "cool" factor <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" />
100% load temps using TAT are 57-59 at 3330 MHz. on air.<br />
<br />
How much cooler does water generaly keep a system? My goal is to be able to run an overclock of 3800-4000 MHz. with my system, do you think that I will be able to do that 24/7 with a water cooler?<br />
<br />
Thumper, what do you run yours at?
1 - 3 of 3 Posts
