ASUS P5P43TD Pro Boot Failure
3077 Views 0 Replies 1 Participant Last post by  David83
This is a new pc I purchased this week.
The parts that can possibly have the problem are these:
(the rest are all tested on other pcs)
Motherboard: P5P43TD PRO
CPU:Core 2 Duo E8400 3GHz
Memory: G-Skill F3-12800CL9D-4GBRL
Tested with 2 working fine power supplies.
The PC was new, worked fine for 1 day, and the next morning I pressed the on/off button and nothing worked anymore.. The hard disk LED was on all the time, the power LED was off, the GFX card fan by a strange way worked at full speed all the time, all other fans/hard discs/dvd roms were working ok, the screen was totally blank, no posting or any messages, no beeps because the case does not have any installed and so does the motherboard.. So basically I'm stuck here and I don't have another pc with "close to" specs to test them on.
I have also tried reseting the bios, removing everything leaving just the power supply with the GFX card, and the parts above, all case cables are set correctly according the asus manual (I hope it does not contain errors..)
Anyone else have the same problem?
Any help would really be appreciated!
Thanks in advance!
1 - 1 of 1 Posts
1 - 1 of 1 Posts
