1 - 5 of 5 Posts
what are my limitations memory wise
i dont think it can run ddr2
and how high can i go? right now i have ddr400 pc3200
thanks
thanks
Any ddr will work the fastest I seen is PC4400. If it can't work at spec it will downclock itself automatically.
And yes ddr2 will not work because it has socket.
www.komusa.com has PC4700 (DDR566) and PC5000 (DDR600). ^zother is correct, DDR2 will not work...it's a completely different interface/architecture.
PC4700 (DDR566) and PC5000 (DDR600) will both work ?
Any ddr will work they will all clock themselves down. The rating is just what the company rates them up to.
1 - 5 of 5 Posts
