What's Changed?
Troubleshooting
Comparison Charts
P8P67-M
P8P67-M PRO
P8P67
P8P67 LX
P8P67 LE
P8P67 PRO
P8P67 EVO
P8P67 DELUXE
SABERTOOTH P67
P8P67 WS Revolution
Maximus IV Extreme
Reviews
Legit Reviews - P8P67 and P8P67 Deluxe
Pro-Clockers - P8P67 Pro
Bjorn3D - P8P67 Deluxe and P8P67 Pro
Benchmark Reviews - P8P67 EVO
HardwareZone - P8P67
Tom's Hardware - P8P67 Pro
PureOverclock - P8P67-M Pro, P8P67, P8P67 Pro, P8P67 Deluxe, and P8P67 WS Revolution
[H]ard|OCP - P8P67 WS Revolution
Ocaholic - P8P67 WS Revolution
bit-tech - P8P67
Clunk.org.uk - P8P67 Deluxe
Vortez - P8P67
Vortez - Sabertooth P67
Guru3D - Sabertooth P67
Overclock3D - Maximus IV Extreme
TechREACTION - Maximus IV Extreme
HardwareHeaven - Maximus IV Extreme
HardwareCanucks - P8P67 Pro (B3)
[H]ard|OCP - Sabertooth P67 (B3)
ThinkComputers - P8P67 WS Revolution (B3)
Vortez - Maximus IV Extreme (B3)
TechPowerUp! - P8P67 Pro (B3)
PureOverclock - Maximus IV Extreme (B3)
Overclockers - P8P67 WS Revolution (B3)
Overclockers - P8P67 Pro (B3)
PCMHz - Sabertooth P67
HardwareHeaven - Sabertooth P67 (B3)
HardwareMX - Sabertooth P67
Benchmark Reviews - Sabertooth P67 (B3)
3dnews - Sabertooth P67
PurePC - Sabertooth P67
PurePC - P8P67 Pro
Overclock3D - Sabertooth P67 (B3)
Ninja Lane - P8P67 (B3)
HardwareMX - P8P67
HardwareZone - Maximus IV Extreme (B3)
4/22:
- Realtek High Definition Audio Driver: R2.71 (6.01.6886)
Troubleshooting
- FAQ (credit to Korlus and others)
- Tools to flash and recover BIOS on ASUS P8xxx boards (FD44Editor, FTK)
- Asus BIOSes with updated RAID ROM
- [How-to] Flashing NEC/RENESAS USB 3.0 uPD720200/uPD720200A firmware
- [How-to] Downgrade ASUS UEFI BIOS
- [How-to] Update Intel ME Firmware
- [How-to] Update Intel RAID Option ROM
- P8P67 Series Overclocking Guide (credit to the several Asus reps who put it together)
- Click here for a huge, detailed product specification guide.
- Possible fixes for those having booting issues:
Clear RTC RAM procedure
*If the steps above do not help, remove the onboard battery and move the jumper again to clear the CMOS RTC RAM data. After the CMOS clearance, reinstall the battery.
- Turn OFF the computer and unplug the power cord.
- Move the jumper cap from pins 1-2 (default) to pins 2-3. Keep the cap on pins 2-3 for about 5-10 seconds, then move the cap back to pins 1-2.
- Plug the power cord and turn ON the computer.
- Hold down the "Del" key during the boot process and enter BIOS setup to re-enter data.
http://www.hardforum.com/showpost.php?p=1036726695&postcount=1
Originally Posted by OC_Seer
Some of you may have been experiencing a double POST on your P8P67 series motherboard whereupon after powering on the system from a cold boot, the board will power on and then immediately reset itself before it actually POSTs and shows any display on the screen. I'll explain the fix below and give some information about why this happens.
First, I would like to stress the importance of flashing the BIOS to the latest BIOS revision as listed on our support website, http://support.asus.com/download. You can access the ASUS EZ Flash tool from within the UEFI (advanced options, tools) to flash the BIOS from any removable device such as a USB flash drive.
From time to time we needed to implement full resets in order to maintain stability due to the architecture of the Sandy Bridge platform. For instance, the system may require one full reset when the PCH power has been cut during S5 power state. To fix the most common additional reset (double POST when powering on from off state), enter UEFI BIOS -> go to 'Advanced' tab -> go down to 'APM', press Enter -> enable the "Power on by PCIe." function. Then press F10 to save & exit. After save & exit, let the system boot into Windows or other OS, then perform a proper shutdown: Start button -> Shut down. You will no longer have the double POST. We will fix this in an upcoming BIOS release.
Comparison Charts
P8P67-M
PRODUCT LINK
Manual / Memory QVL List
BIOS
Version 3608
- Improve compatibility with Windows 8 OS.
- Improve system stability.
- Enhance compatibility with some USB devices.
- Fixed Nvidia GTX 680 hang when running with UEFI driver.
- Support new CPUs.
Version 3603
- Improve memory compatibility.
Version 3602
- Support new CPUs.
Version 1701
Version 1501
- Support new CPUs.
Version 1002
- Fix function "AC Power Loss" failure issue in some conditions.
Version 0901
- Fix system hang if the HDD is NTFS format and the allocation unit size is not 4096 bytes.
- Fix Bitlocker function fail on Drive C.
Version 0805
- Add item "Wait For 'F1' If Error" to skip "Press F1......".
- Fixed Crashfree fail when Memory above 4G.
Internal Beta Version 0503
Version 0408
- Remove "Chassis Fan 2 Speed" in Monitor.
- Improve System Stability.
Version 0404
- Iniital release.
Chipset
Audio
- Intel INF Driver: 9.4.0.1017
- Intel Management Engine Driver: 9.0.1.1333
- Intel Management Engine Firmware: 8.1.30.1350
Lan
USB 3.0
- Realtek Gigabit Ethernet Driver
- Windows 7 - 7.069.0304.2013
- Windows 8 - 8.012.0304.2013
SATA
- ASMedia USB 3.0 Driver: 1.16.2.0
- ASMedia USB 3.0 Firmware: 120816_02_02_6D
Utilities
- Intel Rapid Storage Technology Driver: 12.5.0.1066
- AI Suite II
- Asus Update 1.01.02
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.37
- ImageResource
- Matrix 1.02.22
- MyLogo 1.01.16
- Probe II 1.00.29
- System Information 1.00.22
- TurboV EVO 1.00.68
P8P67-M PRO
PRODUCT LINK
BIOS
Version 3608
Version 3603
Version 3602
- Support new CPUs.
Version 1004
Version 1002
- Enhance compatibility with some USB keyboards.
Version 0901
- Support new CPUs.
Version 0720
- 2.2TB or larger HDD can be supported under RAID mode.
Version 0713
- Fixed some PCIE cards will down to GEN1 after S3 on PCIEx16 slot.
Version 0709
- Fixed system hang if the HDD is NTFS format and the allocation unit size is not 4096 bytes.
Version 0708
- Fix crashfree maybe fail when bios upgrade.
- Added Print Screen help string.
Internal Beta Version 0601
Internal Beta Version 0414
Version 0413
- Fix Blue Screen of Death when plug Graphics card installed into pciex16_2.
Internal Beta Version 0404
Chipset
Audio
- Intel Management Engine Driver: 9.0.2.1345
Lan
USB 3.0
SATA
Utilities
- Marvell SATA Controller Driver: 1.2.0.1032
- AI Suite II
- Asus Update 1.01.03
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.41
- ImageResource
- Matrix 1.02.22
- MyLogo 1.01.18
- Probe II 1.00.29
- TurboV EVO 1.00.80
P8P67
REV 3.0 PRODUCT LINK / REV 3.1 PRODUCT LINK
Manual - REV 3.0 / REV 3.1
Memory QVL List 1 | List 2 | List 3
BIOS
Version 3602
- Support new CPUs.
Version 3509
- Support new CPUs.
Version 3301
Version 3207
- Support new CPUs.
Version 2303
Version 2103
Version 2001
- Enable support for Next Gen 22nm Processor.
Beta Version 1850
Version 1704
- Improve S4 resume support under GPT boot configuration.
- Improve EPU support for new CPUs.
- Improve USB compatibility.
- Improve PCIE RAID card compatibility.
- Improve S3 resume support when using high frequency DRAM.
- Enable support of IRST 10.5.x.
- Change CPU temperature display from Tjunction to Tcase.
Beta Version 1608
- Enhance support for Game Port on old audio cards.
- Enhance SATA compatibility.
- Enhance mouse/keyboard support under UEFI.
- Enhance USB2.0 / 3.0 legacy support.
- Enhance PCIE compatibility.
- Enable support of CAS = 4 DDRIII-1333 modules.
Version 1503
- Display warning message when press F12 and there is no usb flash plug in.
- Fixed the TPM setup item displays abnormally after load-default .
- Fixed the CPU/turbo ratio is wrong after clear CMOS.
- Fix mouse cursor may be drift if there is a joystick plug in.
- Fixed that xhci legacy support function fail if there is another PCIE usb3.0 addon card on the system.
- Change the maximum value of CPU (turbo)ratio to 1-core maximum turbo ratio.
Internal Beta Version 1506
Version 1401
- Increase Hardware Compatibility.
Version 1305
- Enable the display of Intel PCH revision BIOS Setup Screen for the ease of recognition for B3 stepping chipset.
- Enable support for ROG BIOS Print.
- Enhance SAS card compatibility.
- Enhance auto rule for better performance.
- Support new version AI Suite II (must work with new AI Suite II).
- Enable support for onboard Bluetooth disable capability.
- Enable support of "Wait For 'F1' If Error" option to allow user to ignore BIOS warnings during POST.
Internal Beta Version 1302
Version 1204
- Reduce boot time if clear RTC.
Internal Beta Version 1253
Beta Version 1053
- Enable support of "Internal PLL Overvoltage" item to allow better CPU Turbo Ratio overclock capability with D2 Stepping processors.
Version 1003
- Update CPU ratio item to allow automatic activation of Intel Turbo Boost when CPU Ratio is above the Intel specification.
- Enhance PCH native SATA performance.
- Enhance USB 3.0 / PCIE performance.
- Enhance USB 3.0 compatibility under BIOS setup screen.
- Enhance USB compatibility.
Version 0804
- First Released.Version 3602
- Support new CPUs.
Version 3510
- Support new CPUs.
Version 3207
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2103
Version 2001
Beta Version 1850
Version 1704
Version 0105 (REV 3.1)
- First release.
Chipset
Audio
Lan
Bluetooth
USB 3.0
- Atheros AR3011 Bluetooth Driver/Suite
- Windows 7/8 - 7.4.0.160
SATA
- (REV 3.0) NEC USB 3.0 Driver: 2.1.39.0
- (REV 3.1) ASMedia USB 3.0 Driver: 1.16.2.0
- (REV 3.1) ASMedia USB 3.0 Firmware: 120816_02_02_6D
Utilities
- JMicron JMB36X Controller Driver: 1.17.65.11
- AI Suite II
- AI Charger 1.00.06
- Asus Update 1.02.03
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- FAN Xpert+ 1.00.46
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
- System Information 1.00.29
- TurboV EVO 1.01.18
- USB 3.0 Boost 1.02.06
P8P67 LX
PRODUCT LINK (unavailable)
Manual / Memory QVL / Device QVL
BIOS
Version 3608
- Support new CPUs.
Version 3603
Version 3602
- Support new CPUs.
Version 0404
Version 0402
- Support new CPUs.
Version 0305
- First release.
Chipset
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- AI Charger+ 1.00.06
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.41
- ImageResource
- Matrix 1.02.22
- MyLogo 1.01.18
- Probe II 1.00.29
P8P67 LE
PRODUCT LINK
BIOS
Version 3608
- Support new CPUs.
Version 3603
Version 3602
- Support new CPUs.
Version 1104
Version 1101
- Support new CPUs.
Version 1013
Version 1011
- Fixed some cards will down to GEN1 after S3.
Version 1003
- Support F12 hot key in BIOS Setup.
Version 0709
- Update Asus SPD information in Setup.
Version 0701
- Initial release.
Chipset
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.37
- ImageResource
- Matrix 1.02.22
- MyLogo 1.01.16
- Probe II 1.00.29
P8P67 PRO
Device QVL List / Memory QVL List 1 | List 2
BIOS
Version 3602
- Support new CPUs.
Version 3207
- Support new CPUs.
Version 2303
Version 2103
Version 2001
Beta Version 1850
Version 1704
Beta Version 1606
Version 1502
- Fix system maybe hang if the NEC Chip F/W is broken.
Version 1305
- Support new version AI-SuiteII(must work with new AI-SuiteII)
Version 1204
Beta Version 1053
Version 1003
0804
First Release.Version 3602
- Support new CPUs.
Version 3207
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2103
Version 2001
Beta Version 1850
Version 1704
Version 0105
- First release.
Chipset
Audio
Lan
Bluetooth
- Intel Gigabit Ethernet Driver: 18.2
USB 3.0
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
P8P67 EVO
PRODUCT LINK
Manual / Device QVL List / Memory QVL List 1 | List 2
BIOS
Version 3602
- Support new CPUs.
Version 3207
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2103
Version 2001
Beta Version 1850
Version 1704
Beta Version 1606
Version 1502
- Fix the CPU/turbo ratio is wrong after clear CMOS.
- Fix that xhci legacy support function fail if there is another PCIE usb3.0 addon card on the system.
- Improve TPU's algorithm to bring better performance on some CPUs.
Version 1305
Version 1204
Beta Version 1053
Version 1003
Version 0804
- First Released.
Chipset
Audio
Lan
Bluetooth
USB 3.0
SATA
- NEC USB 3.0 Driver: 2.1.39.0
Utilities
- AI Suite II
- AsusUpdate 1.02.03
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
P8P67 DELUXE
PRODUCT LINK
BIOS
Version 3602
- Support new CPUs.
Version 3509
- Support new CPUs.
Version 3207
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2103
Internal Beta Version 2101
Version 2001
Beta Version 1850
Beta Version 1703
- Improve DRAM compatibility.
Version 1702
- 2.2TB or larger HDD can be supported under RAID mode. (Need to install Intel Rapid Storage Technology 10.5 version driver first)
Beta Version 1606
Internal Beta Version 1505
Version 1503
- Improve system compatibility.
Version 1502
Version 1305
Version 1204
Beta Version 1053
Version 1003
Version 0804
- First release BIOS.
Chipset
Audio
Lan
Bluetooth
USB 3.0
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
SABERTOOTH P67
PRODUCT LINK
BIOS
Version 3602
- Support new CPUs.
Version 3302
- Support new CPUs.
Version 3209
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2103
Version 2001
Version 1904
- Support new CPUs.
Beta Version 1850
Version 1801
- 2.2TB or larger HDD can be supported under RAID mode. Need to install Intel Rapid Storage Technology 10.5 first.
Beta Version 1606
- Enable support of CAS = 4 DDR3-1333 modules.
Version 1502
- Enhance USB input device compatibility under UEFI interface.
- Enhance XHCI Legacy support.
- TPU firmware updated to enhance the effect of TPU on some processors.
Version 1305
- Enable AI Suite II to be installed under OS license activated by third party software.
- Enable support for TurboV EVO module inside AI Suite II.
Version 1204
Internal Beta Version 1053
Version 1003
Version 0901
Chipset
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
P8P67 WS Revolution
PRODUCT LINK
BIOS
Version 2105
- Show DRAM frequency on EZsetup.
- Correct CPU speed at CPU information.
- Support new CPUs.
[Note]
- Please noted that MB need to install Sandy Bridge CPU to upgrade BIOS from 1503 to 2xxx.
- Please noted that BIOS need to flash twice to upgrade completely, attachment SOP for your reference.
- Please noted that the later BIOS of 2xxx supports only MBs of B3 stepping. If you have B1, B2 stepping MB on hand, please issue RMA for replacement, thanks.
Version 2003
[Note]
- Please noted that BIOS need to flash twice to upgrade completely.
- After flashing BIOS twice, pls make sure the ME version already upgrade to 8.0.2.1410. User can find the related info on Main page under Advanced mode.
Version 1503
- Always set Window Boot Manager to boot option #1 after update BIOS.
- Modify ASUS board string "ASUSTeK COMPUTER INC."
- Fixed the usb mouse can't work under DOS.
Version 1402
- Update the MRC revision to 1.2.2.
- Update German string of "Save changes & reset".
- Fixed USB Keyboard 3R-FKB3010UBK can't work issue.
- Support Ivy Bridge CPU and PCIE gen3.
Version 1302
- Change the default value of item "Phase Control" to "Standard" from "Extreme".
- Update RAID option rom to support 3TB HDD.
Version 1202
- Add new module to support DOS tool "SCEDOS".
- Increase Hardware Compatible Version.
Version 1103
- Reduce boot time if clear RTC in CMOS.
- Update ME firmware to version 1197.
Internal Beta Version 1007
Version 0804
- Shorten response time of pressed-key with USB Keyboard.
- Update Memory OK display rule for BCLK.
Version 0604
First release.
Chipset
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.00.31
- EPU-6 1.02.16
- Matrix 1.02.45
- MyLogo 1.01.18
- Probe II 1.00.29
Maximus IV Extreme
PRODUCT LINK
BIOS
Version 3603
- Support new CPUs.
Version 3510
Version 3211
Version 3208
- Support new CPUs.
Version 2302
- Support new CPUs.
Version 2105
Version 2001
Version 1904
- Support new CPUs.
Internal Beta Version 1902
- "Xtreme Tweaking" option for 3D01 in BIOS.
Beta Version 1850
Internal Beta Version 1596
- Fixed some bugs.
Internal Beta Version 1485
Beta Version 1409
- Improved OC performance using Multipliers or Auto Overclocking.
- Improved BCLK and DRAM OC capabilities when enabling the "Internal PLL Overvoltage" option in BIOS. Note - Sleep/Hibernate will not operate properly due to Intel Specs.
- Improved USB compatibility, performance and UEFI fixes.
- Minor Bug Fixes.
- Adds EFI ROM flash back -> from one ROM to another -> to fix BCLK unable to change after failed flash.
Version 1303
- Improve OC performance.
- Enable CPU Multiplier upper limit to 59x for K series CPU.
Internal Beta Version 1298
Version 1204
- Improve USB3.0 compatibility.
Version 1101
Internal Beta Version 1090
Internal Beta Version 1052
Internal Beta Version 0089
Internal Beta Version 0088
Internal Beta Version 0951
Internal Beta Version 0950
Version 0901
Internal Beta Version 0066
Version 0802
- Improve Overclocking capability and system stability.
Internal Beta Version 0681
Internal Beta Version 0675
Internal Beta Version 0654
Internal Beta Version 0653
Internal Beta Version 0077
Internal Beta Version 0065
Internal Beta Version 0056
Version 0504
- Support print screen in setup Ez mode.
Version 0406
- First Release BIOS.
Chipset
Audio
Lan
Bluetooth
USB 3.0
- Toshiba Bluetooth Stack Driver: 9.10.00
SATA
Utilities
Reviews
bit-tech - P8P67
Vortez - P8P67
PurePC - P8P67 Pro
HardwareMX - P8P67
