Did you connect your other MOBO connector?
The 6 - 8 somewhat one, it is usually above the processor socket.
You mentioned you tried a different PSU, do you have a spare computer laying about to test the PSU that is currently not working?
It might help you in your journey.
Originally Posted by StormX2 ![]() Tried booting the sig rig up with the PC Power & Cooling 750 Watt Silencer-Quad PCIe 80A Red Version Now once everything was connected, the Lights on the Motherboard for the Power and Reset Light up, but it won't power up no matter what I did.. Now I just don't see how I could have missed a power plug, Standard mobo Power (24 pin?) is all the PSU had so That plugged in easly, and the 8 pin 12v Connector also no issues there. Only thing that bugged me was a Pin connector above the CPU labled "CPU FAN" at which point liek all my other builds you connect the Fan for the HS. Only thing is, the pin connector is 4 pin? and the Fan that came with my U12P is 3 pin, but that doesnt seem to be a problem.. There is a 4 pin connector of some form with the PSU (instruction's Suck) but doesnt state where it would go, and Other than the CPU fan, there is no other 4 pin connector on the motherboard. I don't know what is Supposed to connect to the connected labled "PWR FAN" but just looks like a normal 3 pin connector.. So Angry that my computer didnt work, I ripped my OCZ 600 watt out, and Frankensteined it on some boxes. Using 2 4 Pin power connectors, and the 20+4 pin power, HS Fan connected to "CPU FAN" and the nifty little Shipset Cooler connected to "PWR FAN" (no different from before though. Difference is, Computer boots up, Loaded Win XP on a fresh 250gb Drive that I had (only running 3 x 1 gb 1333mhz atm.) So is this PC Power and Cooling a Dead PSU? With that one it never starts the fans or boots. with my POS 600watt OCZ I seem to have no issues. Also, if I will be using the OCZ For a while, I wonder if anyone knows the best way to keep an eye on Voltage and such from the PSU, as I wouldnt want it to not power well enough. All information and help greatly appreciated. |
