1 - 3 of 3 Posts
Let me know if any of this is possible.
This board has two gigabit lan ports.
I am upgrading my internal network to gigabit.
I understand that my Uverse router will always run at 10/100, but I am throwing a gigabit switch in front of it so my internal network is a gigabit.
This board is part of my gaming machine, which is also now my media center. i will be streaming movies via Plex to my Google TV. Pretty soon I will be adding another GTV in the bedroom and it will also stream to that.
Can I utilize those two lan ports? Can I load balance them, or team/bridge them to increase speed?
I am running windows 7.
You need to put a router wich supports link aggregation (802.3ad). Check out link aggregation and channel bonding in google.
I managed to do it on a linux box and a netgear gs724tp switch, but never tried on Windows.
In the best case, with channel bonding, 2x 1Gbps = 4Gbps
BTW, be carefull about the RJ45 wiring, ethernet 100mbits use 2 pairs, the 2 others are for phone & tv, or 2x phone.
Ethernet gigabit need the 4 pairs (4x 250mbits), so you can't use the cable for the phone.
1 - 3 of 3 Posts
