I see various threads with specific questions about the P6T, but none that answer my questions so here I am. Anyway, time to get to it...
I see that the P6T has an ATX12V socket with what appears to be a cover over the remaining 4 pin sockets that would make it an EPS12V socket. Does this mean I can simply plug in an EPS12V cable into the P6T by removing the cover or do I need to use an ATX12V cable? Do I get any extra benefits from plugging in the EPS12V line over the ATX12V, such as better overclocking abilities?
I understand that BCLK is the key variable to manipulate for overclocking the CPU, and the memory multiplier for overclocking the RAM, but what other voltage variables or clocks are important for overclocking this board? For what it's worth, I'll be using an i7 920 with 3x2GB of OCZ XMP Ready DDR3 1600 RAM.
Are there any aftermarket chipset coolers that will work for the north and southbridges of this motherboard? I am not sure if mounting conditions have changed for the ICH10R southbridge or X58 northbridge. Are the MOSFET cooler mounting holes generic? How are chipset temperatures on this board?
What does the ICH10R top out at in terms of HDD transfer rate? I currently use 4-WD Raptors in RAID-0, but 3 would get me basically the same speed on the ICH7R that I had before and I am not sure if anything has changed. I realize that the SATA ports operate on a single PCI-E lane, but I am not sure what that equates to exactly.
Answers to any of these questions is greatly appreciated!
