1 - 5 of 5 Posts
Hi there OCN. Next week I will be buying this motherboard and just wanted to get a confirmation on the lane speeds. So here is the P6TD Deluxe if you are not familiar.
So what I am asking is, are the blue and white slots the ones that run at x16?
Originally Posted by sn0man
Yes, you can run 3 slots @ x16/x16/x1 --or-- x16/x8/x8.
Ah thankyou very much. So I will have my two GTX's in blue and white then my soundcard in the bottom PCI slot. I sorta wished the black slot was x16 to give a little more space between the sound card and the bottom GTX.
Your GTX's have dual slot coolers right? You cannot put it in the black PCI-e slot unless you have those special cases with 8 or more expansion slots or you are running caseless.
Ah that's the reason!
Thanks, i only have 7 slots. Thanks for the info!
1 - 5 of 5 Posts
