1 - 3 of 3 Posts
Discussion starter · #1 ·
hey guys i was will soon make my first Intel build some time this year with water cooling using Swiftech because i can(even tho its a wast of money). Not sure i will go for Haswell since i will be properly just game and to light encoding, movies and browsing and ****.
i've decide to go with this mobo ASUS P8H77-I Mini ITX Motherboard which will go with the BitFenix Prodigy Mini-ITX Case.
The only thing it has only a 4 pin cpu power, which will properly power up a i5 3550 i could get an i5 2500k but this mobo is a H77, and is not gonna overclock.
The only thing that worries me is because it has 4 pins instead of the usual 8 pin and was wondering if there is any disadvantage other than overclocking that i should know.
Yes it does have an effect on overclocking. I also can't find any information on how many phases that Asus board has leading me to believe it has very little, which would also have a negative effect on OC'ing.
I would suggest an ASRock ITX Mobo, here are two of them I found for you.
This one is cheaper than the Asus, it only has a 4 pin cpu power but it lists that it has 4+2 phase for the CPU.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157311
and this one is a bit mor expensive but had an 8 pin power for the CPU and a 6+2 phase, this one seems ideal if it fits the budget.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157312
Let me know if these don't suit you or if you have any questions.
1 - 3 of 3 Posts
