Hi this is my first post concerning my first build. Here's the problem I built my computer and turned it on it turned on for about 5 seconds turned off and then switched itself back on again, throughout this the memok has remained on (not flashing) Ithen held the memok button until it started flashing it kept flashing for around 10 minutes and then the computer switched itself off I turned it back on around 2 mins later and it did exactly the same as it did the first time only this time the memok button flashed throughout I turned off the machine and removed the psu plug from the socket and then checked the ram was inserted correctly into the dimm slots I am now about to try switching it back on. Here are the specs in case you need them.
Case - haf 932
Mobo - asus p8p67 Eco
CPU - Intel I7 2600k
Ram - corsaire xms3 8gb ddr3 (2x4gb)
Further information: I have placed the ram into the 2nd and 4th slots also I have not heard the computer beep at any point
any help would be greatly appreciated
Case - haf 932
