About to upgrade and decided on these parts:
i5 2500k ( would like to oc to 4.5ghz )
Hyper 212 plus cpu cooler
2x coolmaster sickle flow 120mm (for the cpu cooler)
8gb ddr3 Corsair Vengeance ram
2x Gigabyte OC 6850s ( already have these so can't change them )
Corsair HX650 650W Modular Power Supply
Antec Dark fleet DF-85
or the red and white phantom http://www.computerlounge.co.nz/comp...p?partid=15851
Last thing I have to decide on is the motherboard, what advantages will I gain from having the Asus P8Z68? Its quite a bit more expensive and just wondering if its worth getting over the Gigabyte. Also if there are any suggestions to what I'm getting that would be appreciated.
Thanks
Thanks
