1 - 20 of 279 Posts
Are there any P9X79-E WS owners here at OverClock.net? It's getting a bit lonely around here <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif">
Iconoclast
I don't own one, but I've been considering a second LGA-2011 build, and am seriously considering the P9X79-E WS. I used to have a P9X79 WS and was pretty impressed with it.<br><br>
How do you like your board? How mature is the BIOS?
Hi Blameless,<br><br>
I'm really happy with this motherboard. It's been very stable under load and and trouble free so far. I have it mildly overclocked since stability is top priority for me. So I can't really comment regarding it's aggressive overclocking capabilities. So far, there's been one BIOS update from Asus. I will update my signature with my system spec tomorrow. The only problem I had with the board is that the bottom memory tabs are too close to the first PCI-e slot and could prevent some video cards from being installed on the first PCI-e slot. So if stability and performance is what you're looking for, I don't think you'll be disappointed.
Own one and currently doing a build with it. Haven't even powered it yet and I love it. Post more here as the build progresses.
I have had mine for about 2 weeks now. So far VERY happy with it. The BIOS is awesome, works well and a LOT of features even for an enthusiast.<br><br>
At the moment I have a 3820 installed, waiting for 4960X to be released.<br><br>
Paired up with SLI Titans and 3 x 24" Asus screens.<br><br>
Also custom WC system.
Reactions: Blameless
Checked under the hood before my return ran out.<br>
Bent pins for processor socket :mad:(<br><br>
RMA but newegg handled it great sent return invoice 5 mins after I got off the phone.<br><br><a class="H-lightbox-open" href="http://www.overclock.net/content/type/61/id/1610363/"><img alt="" class="lightbox-enabled" data-id="1610363" data-type="61" src="http://www.overclock.net/content/type/61/id/1610363/flags/LL" style="; width: 640px; height: 480px"></a>
Were the pins bent before installing your water block and rigid acrylic tubing?? Or was it an accident on your part?<br><br>
That was my concern when I ordered mine. My concerns were unfounded in my case, but I will be changing CPU's when the 4960X is available.<br><br>
Good luck with it. A great board and fantastic bios!!
Looked like that when I first popped the cover off.<br>
Because of this, I decided just to do the<br>
Cooling on top because it was RMA. Otherwise I would have waited<br>
for the processor.
The BIOS is awesome, works well and a LOT of features even for an enthusiast.<img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"><br><img alt="lce6Z" class="bbcode_img" src="http://goo.gl/lce6Z">
Quick question guys,<br><br>
Since I won't be upgrading from an existing chip and using the 4960x can I update the bios without having a legacy chip in?<br>
I can download the bios onto a thumb drive and update that way but will it have to recognize the chip first.<br><br>
Hope I am explaining this in a way that is understandable.<br><br>
Thanks <img alt="wink.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/wink.gif"><br><br>
Nate
Nate,<br><br>
Sorry to hear that it came that way. I too was very concerned as I had seen a small number of reports that Asus boards had arrived with bent pins. I explained to the e-seller my concerns, but all was ok. I am glad Newegg are looking after you, but you have to wait for a new board.<br><br>
If you are waiting to install a 4960X, then my understanding is that the board is already shipped with the latest bios, ready for IB-E CPU's.<br><br>
As to whether can update the BIOS without a chip present, on some Asus boards you can.<br><br>
Good luck with it all.
Discussion Starter #12
Wow, it's good to see more fellow p9x79-e ws owners. I originally had a very high impression of this board. After three months of heavy use, I'm a bit ambivalent about this motherboard. Overall the board is performing well but it's main feature which is its PCIE lanes are half broken in my case. the main reason I bought this board was for its advertised support for four PCIE 3.0 x16. I don't use this board for gaming and the custom application I run on it performs a lot of GPU to GPU data transfer. So the PCIE bandwidth is utmost importance in this case. Unfortunately, the Nvidia Titan and the 700 series GPU's don't fully support PCIE 3.0 on SB-E. You may not encounter a problem if you are lucky and hit the jackpot and ended up with the right combination of CPU and GPU (bin quality). To make the situation worst is that each company (Asus, Nvidia, and Intel) blames the other ones for this problem. Although, Asus and Nvidia claim that the full support will be there on IB-E platform. Here's the email from Asus:<br>
"Dear ...,<br><br>
After checking with the relative department, they mentioned that it is just the limitation of the Nvidia that the Nvidia adavanced video card will meet the unstable problems when run at gen 3 mode on the X79 boards.<br>
You can have a look at the following link:<br>
<a href="http://nvidia.custhelp.com/app/answers/detail/a_id/3135/~/geforce-600-series-gen3-support-on-x79-platform" target="_blank">http://nvidia.custhelp.com/app/answers/detail/a_id/3135/~/geforce-600-series-gen3-support-on-x79-platform</a><br>
So we do suggest you to run the video cards at gen 2 mode for stable running.<br><br>
Best Regards,<br>
...<br>
ASUS Product Support Team"<br><br><span style="color:#8B0000;"><span style="text-decoration:underline;"><b>The current BIOS version of this motherboard doesn't support the IB-E yet</b></span></span>. The new BIOS with support for IB-E will be out at the end of this month. Here is the email I got fro Asus tech:<br>
"Dear ...,<br><br>
Currently I haven't recieve the the accurate date, but the released date will be around End of August.<br>
Supposely Ivy Bridge CPU should be compatible with Gen3 VGA card according Nvidia announcement.<br><br>
Best Regards,<br>
...<br>
Going to use this board with three Titans and the 4960x chip when it comes out. Like I imagine a lot of people did, I bought this board specifically because of the 4 way x16 gen 3 PCI.<br><br>
I'm in the same boat as you- need every inch of bandwidth between cards. I really hope that since it should be "Native" with the new ivy-e all of this issue will just go away. If not, Nvidia and Asus have some splaning to do as this was the big selling point of this board- a graphic workstation high performance board.<br><br>
We will just have to wait and travel down this one together. If I find out anything I will post here along with what I experience and please do the same.<br><br>
Cheers and best of luck to everyone for happy and stable computing!<br><br>
-Nate
Discussion Starter #15
@sabishiihito, The Titan doesn't need the registry hack to enable Gen3. If your PCIE slots are switched to Gen3 in the BIOS they will run on Gen3 out of the box which mine do. The problem is not enabling the cards to run on Gen3. The problem is that the CPU's based on SB-E have many Errata listed for the PCI-E controller, one of them includes a negotiation issue that results in the CPU<-> GPU link not being stable and generating an excessive amount of errors and causing performance degradation. This might not cause the machine to crash but it will definitely impact the bandwidth in a negative way. I have witnessed this in our in-house benchmarks.<br><br>
@chgoyoshi, I also have a Xeon E5-2670 which according to Intel fully supports the Gen3 but still is based on SB-E. The problem still persisted with the the Xeon. The E5-2670 is still based on the SB-E platform though.<br><br>
I do hope this is fixed on IB-E <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif"><br><br>
Please, do keep us updated as you find any new information. I will do the same.
Hi Ardi,<br>
I have just finished building a rig with this motherboard and so far no problems (Only been up and running for 2 days).<br>
My rig consists of: Corsair C70 case, Asus P9X79E-WS motherboard, XFX 1250 Black Edition power supply, Intel Core i7 3930K processor, Corsair Dominator Platinum 32GB 1866MHz C9, Sapphire HD 7970 VaporX 3GB graphics card, Samsung 840 Pro 256GB SSD, WD Velociraptor 1000 DHTZ 3.5 HDD, All Noctua fans throughout, running Windows 8.<br>
Checkout my default album in 'natbabs' for visual display of the build.
Discussion Starter #17
Hi Natbabs,<br><br>
Welcome to the P9X79-e WS owners thread. You've gotta great build <img alt="specool.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/specool.gif"> It's nice to see the P9X79-e WS community growing <img alt="smile.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/smile.gif">
Natlabs, nice build!! My son has the same case, with my "old" Gigabyte Z77-UP5-TH motherboard and 3770K. I did exactly the same thing as you with the side window, although not as nice as you <img alt="biggrin.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/biggrin.gif"><br><br>
The Asus is a a great motherboard, very happy with it. I currently have a 3820 in it, which is running at 4.3Ghz 24/7 stable and cool. I was thinking of dropping a 4960X in, when released, but my other hobby (RC Planes) is taking up valuable $$$$ will probably go with a 4930K.<br><br>
Too many expensive hobbies, not enough $$$$$<br><br>
Cheers<br><br>
Rob
Yeah, I hear you on the 'not enough $$$!' My build has cost me dear (in my case ££££) - I think I will take up knitting.....?!! <img alt="rolleyes.gif" class="bbcode_smiley" src="http://files.overclock.net/images/smilies/rolleyes.gif">
I'm eying up this board, but I'm a little concerned with how close the memory slots are to the first PCIe slot.<br>
Has anyone run into any problems of not enough room when installing a video card with a backplate or memory with heat spreaders that extend longer than the contacts lengthwise?
1 - 20 of 279 Posts
