Hey folks. I bought my build for 1.5years ago or summit. I played around with some small oc`ing and everything went fine.. Then i updated my bios to ver 0308 and after that i never got any oc to work, so i didnt bother much and have used it stock for around a year.. Now ive been playing around on COD:MW2 and exp some small problems around that and wanted to try and oc this system a little to see if that helps.. Ive tried to find some easy setups, to what to set in the bios, but it will never boot and if it does it sais that the oc failed press f1 to go in to bios or f2 to set to default and boot (or summit like that) I thought that maby the bios verson i have is bad and wanted to try and flash to a newer one.. Ive gotten the 0803 verson, but i cant seemn to find the EZ Flash 2 program ive red so much nice about. And that freakin Asus site newer work! I get errors, it wont load right, half the page loads and after the hundred and fifth time i finally got the bios file down, but cant find the flash tool.. Anyone of you guys able to help me with a linky, and maby a though/"try this setup" thing in bios to get it OC`d with current bios ver?
