541 - 552 of 552 Posts
Hi, I have the 2404 bios and I can no longer put an override + 250mhz. Once under windows I have a +200 while in the bios it's + 250Mhz, any idea? On the 1602 bios it was possible, what is the last bios that can still make a + 250mhz? Thank you
Did you figure this out? I know it was dropped at some point, 1602 might even be the last one.
New bios for the B550-E. Strange changelog lol ->
Version 2407
2021/07/21 20.53 MBytes
ROG STRIX B550-E GAMING BIOS 2407
"Support WIN 11 installed or upgraded
Not new to Overclock.net
I don't see what's strange about it. It's saying Windows 11 is supported better whether you installed it clean or if you upgraded via Windows Update.
There is one thing that's strange for me though: I'm still using BIOS 2201 which is a beta and Windows 11 is working fine for me.
Exactly, why the bios should change in order to run windows?
I don't know about any other changes but 2407 has the fTPM option enabled by default now. Since Windows 11 requires that to enabled that's probably what the patch notes refer to.
Does bios 2407 include changes from previous beta bios 2404? Asus changelogs are very limited.
Looks like they went back to AGESA 1.2.0.3a in 2407 rather than 1.2.0.3b which was in 2404.
I was on 2401 before, so trying 2404 now.
Not sure if it was a mistake on my part, but I lost my core offsets changing versions. All my other settings carried over (loading a saved profile).
Discussion Starter · #549 ·
2407 is indeed patch A, worked with same settings as 2404 for me. Wonky first boot though, had to press and hold power three times then it started going through the normal training routine and booted with fclk 1900 right away. No F1. Looks stable so far, and performance looks normal maybe a tiny bit below but it's extreme hot ambient temps now I guess it will be "normal" when it's cooler outside.
Guess ill hold off on updating, using 2403
