Ok, UPDATE!! So far i'm extremely happy with this board. Basic memory settings applied and pretty much "just works" FINALY. My only question is what settings can I adjust/re-adjust for better latency? MSI words the memory options a little different, so i couldnt copy/paste my settings, but ive set pretty much the common ones:I would still go with 707 from what I have seen. Hurry up and get that thing going. I wanna see how this goes.........I am thnking it will do better but if not you got one of the worst IMCs yet lol. I wanna know which it is
I still havent tried 807 or 808 myself. Most of the feedback I have read has been negative. But I do believe each person need to test/try a new bios for themself(as there as so many variables between systems). I just dont have a need as currently running 4133c15 2x16 with no issues on bios 707.
Edit Updated with a link to my setting in a txt file and cmo if you or someone else want to check it out. It is some manual timings and voltages. The CPU OC(AI Optimized) could probably be better with manual setting but I havent got to that yet.
You now if this is the same that was posted 6 days ago to improve 4x8 sr bdie ?ASUS Z690 Series D4 motherboard Last Bios
1. Improve system performance
ROG STRIX Z690-A GAMING WIFI D4 BETA BIOS 0808
Are you using the same version?You now if this is the same that was posted 6 days ago to improve 4x8 sr bdie ?
I`m using the 0808 posted on this forum 12/07/2021Are you using the same version?
If the version is the same, it is the same
In Bios 0808 for Strix Z690-A D4 is also old 0x12 Intel microcode, what is going on by Asus!? In the older Beta Bios 0803 is the newer 0x15! The same problem exists with the new official 0807 Version, also the old 0x12 microcode!ASUS Z690 Series D4 motherboard Last Bios
ASUS PRIME Z690-P D4 BETA BIOS 0806
ASUS PRIME Z690-P WIFI D4 BETA BIOS 0806
ASUS PRIME Z690M-PLUS D4 BETA BIOS 0901
TUF GAMING Z690-PLUS D4 BETA BIOS 0808
TUF GAMING Z690-PLUS WIFI D4 BETA BIOS 0808
Does the newer microcode perform better? I never compared them. I did see a post recently by @shamino1978 about the newer mc is not always better.In Bios 0808 for Strix Z690-A D4 is also old 0x12 Intel microcode, what is going on by Asus!? In the older Beta Bios 0803 is the newer 0x15! The same problem exists with the new official 0807 Version, also the old 0x12 microcode!
Yeah So there is no need to reupdate if the bios version is the sameI`m using the 0808 posted on this forum 12/07/2021
They show the same date: 12/06/2021, so they are the same, I guess
Thanks for the clarificationI uploaded back to this thread for d4 mb users![]()
Security fixes and more in new microcodes. Asus is writing on the page from the board there is new microcode in the new official bios 0807, but this is not truth! In Bios 0807 is the same microcode as in the old 0707, in both versions is Version 0x12! In Beta Bios 0803 it is the newest 0x15! Also in 0808 is the old 0x12!Does the newer microcode perform better? I never compared them. I did see a post recently by @shamino1978 about the newer mc is not always better.
