ThanksNo, 2010 is just the latest official Bios. 2101 is newer but still a test Bios
I was able to download it. thank you for the tip.Replace 2010 with 2103 in the link above and you'll get the latest official release. I found it through EZ-FLASH in my BIOS, but it only got to 14% both times I tried to download it using EZ-FLASH. It didn't get to the flashing stage.
Man that's weird, I looked up the non-WiFi model (which I'm running) and they only have the 2010 on the Singapore site, then the US has anything over 1302 missing for the WiFi. Apparently 2103 bumps the AGESA slightly.Found 2103 on ASUS Singapore. Not tried it yet but they also have 2010 listed too.
https://www.asus.com/sg/Motherboards/ROG-Crosshair-VIII-Hero-WI-FI/HelpDesk_Download/
On the C8H the cha/chb voltage works as a percentage of your DRAM voltage. So if you are running 1.4v dram then 0.68 will actually give you 0.95v for cha/chb. Took me a while to figure that out on mine.Can anyone get there Vref (CHA/CHB) voltages above 0.68v? Dram calculator says to set it at 0.71Vbut it will not go above 0.68v. Thanks
Here you go.Their sites are messed up, depending on the region they display different bios.
Did anyone try 2103 on CH8 WiFi?
Thanks for that much appreciatedOn the C8H the cha/chb voltage works as a percentage of your DRAM voltage. So if you are running 1.4v dram then 0.68 will actually give you 0.95v for cha/chb. Took me a while to figure that out on mine.Can anyone get there Vref (CHA/CHB) voltages above 0.68v? Dram calculator says to set it at 0.71Vbut it will not go above 0.68v. Thanks
If you save your settings to a .CMO file you can apply them that way. The other profiles tend to fail after a bios update.can not apply old setting to 2103, be aware.
It allows the user to offset both the VDDCR_CPU (CPU cores) and VDDCR_SoC telemetry that is seen by the CPU.Just updated BIOS to 2103. I noticed new settings: CPU Telemetry and SOC Telemetry. It seems to involve something about motherboard power reporting? Does this setting have something to do with Power Reporting Deviation that was discovered recently?
