9221 - 9240 of 11805 Posts
Hmm interesting, I would understand the B550 board (heard they are better for ram OC) but the Elite is x570 right?
Yes it is
I got 4x16 gb and can confirm that its super try hard to run 3800:1900. Max I get was 3733. I beliave we need to play with AddrCMDEsetup, CsOdtSetup, CkeSetup in order to run properly. Gigabyte mobos seems to be auto adjust this values to run as u wish. I managed to 2x16 with CR 1T and cl13. Also after 3801 I cant get 4x16 to run even at 3733, only 3600. View attachment 2535072 View attachment 2535073
Yea, I can run 64GB at 3600:1800 just fine.
Currently I'm running 48GB (2x16 + 2x8) at 3800:1900 cl14, but now I have a 32GB 3800c14 kit in the drawer collecting dust...
It's a shame for such an expensive board to be outdone by others that cost half as much. But even so I don't plan on replacing it anytime soon 😅
For the 5950x:
If EDC is more than 140a, then FIT VID is 1.425v.
If EDC is equal to 140a, then FIT VID is 1.5v.
Edit: And my motherboard is an Asus Crosshair VIII Extreme.
Gamer and overclocker !
3902....a good Bios :p
Furniture Table Product Chair Font
240/130/140
-30 all Cores
+200MHz Boost Clock Override
LLC 2
22°C ambient
=> Too hot during Realbench (Max CPÜ CCD1 Tdie > 90°C), so no valid OC for me.
Here is now my valid OC with best compromise temperature/performance/stability :
230/125/160
-30 all cores
+200MHz
LLC 2
Table Font Chair Couch Curtain
Stable 8 hours Realbench :
Font Screenshot Software Parallel Rectangle
Really satisfied with these CBR20 scores, as until 3801, I had difficulties to go beyond 9000 MT sscore
And ST score, I get ~ 640 points, which was roughly what I got with my 3801 stable OC
When 3902 is realeased as final version, I will confirm this Realbench stability and also will make Karhu's (20000%) and Aida64 Cache stress test (4 Hours).
New [email protected]°C with my stable OC with 3902 Beta.
I could pass 9200 pts MT score !!
642 ST score, pretty good also !
Product Table Font Window Line
230/125/160
-30 all Cores
LLC 2
So Happy with 3902 (y)
Your maximum VID is above 1.425v with EDC=160? Not sure what is going on with my combination of 5950x and CH8X.
No, my Vid max is 1.413V.
I discovered some posts ago the behavior of this Bios that you reminded today :
Setting EDC > 140 helps a lot for CBR20 MT score, if you have a mid end cooler as mine (H115i RGB Platinum).
I never had MT score > 9200 since I have my build ! (Jan 2021).
But, this gives a little penalty at ST score. 642 score is still pretty fine for me.
Reactions: safedisk
Ryzen 3950X > 32GB G.Skill GTZN 3600 > ROG Crosshair VIII > NVMe Rocket 1GB > Fractal Define 7 + S36
  • Love
Reactions: GRABibus
9200 ? Lol... let me have a look at those settings 😁
I did these run with Hwinfo not running (better results).
I also ran CBR20 MT 3 times and got this score.
The first 2 runs were at 9100.
Cache effect ?
If we have some saved OC profiles in 3902 bios, can we load them with 3903 without any issues ?
It will avoid to reenter all settings manually…
Some user said about CPU Cache L1 Errors and the new bios 0503 doesn't seem to have any problems
I first saw this error message haha
If I didn't have this cache error and WHEA error issue with 3902, is it worth updating to 3903?
Reactions: GRABibus
3903 doesn't seem to change the max VID when EDC is above 140, but my clocks seem better than 3902 in this scenario. On 3902, my max SC on my 5950x clock was around 4950 with my PBO settings (220/160/190). On 3903, I'm hitting 5050. On 3801 I was getting around 5075. All of these with the best CO I could stabilize (better values on 3902/3903 than 3801) and +50 boost clock.
On 3802, my personal best was 29905MC, 1660SC. On 3903 I can achieve 29778MC, 1656SC. But my temps are much lower on the SC test (presumably due to the limited voltage?). I'll take it!
Nice!
Mind sharing your BIOS for reference?
BTW, I just killed my windows fooling with RAM OCing...gotta love daily backups :D
Nice!
Oof, that happened to me the first time I followed the DRAM calculator and I was so scared I bricked my system. T_T
Here's my settings from 3801:
[2021/12/03 09:52:21]
Ai Overclock Tuner [D.O.C.P. Standard]
D.O.C.P. [D.O.C.P DDR4-3603 14-14-14-34-1.45V]
BCLK Frequency [100.0000]
Memory Frequency [DDR4-3733MHz]
FCLK Frequency [1866MHz]
Core Performance Boost [Auto]
CPU Core Ratio [Auto]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX0 Ratio [Auto]
Dynamic OC Switcher [Auto]
TPU [Keep Current Settings]
Performance Bias [Auto]
PBO Fmax Enhancer [Disabled]
Precision Boost Overdrive [Auto]
Precision Boost Overdrive Scalar [Auto]
Curve Optimizer [Auto]
Max CPU Boost Clock Override [Auto]
Platform Thermal Throttle Limit [Auto]
DRAM CAS# Latency [14]
Trcdrd [15]
Trcdwr [15]
DRAM RAS# PRE Time [14]
DRAM RAS# ACT Time [21]
Trc [35]
TrrdS [4]
TrrdL [4]
Tfaw [16]
TwtrS [4]
TwtrL [8]
Twr [10]
Trcpage [Auto]
TrdrdScl [2]
TwrwrScl [2]
Trfc [243]
Trfc2 [Auto]
Trfc4 [Auto]
Tcwl [14]
Trtp [8]
Trdwr [8]
Twrrd [3]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
Tcke [Auto]
ProcODT [40 ohm]
Cmd2T [1T]
Gear Down Mode [Enabled]
Power Down Enable [Disabled]
RttNom [Auto]
RttWr [Auto]
RttPark [Auto]
MemAddrCmdSetup [Auto]
MemCsOdtSetup [Auto]
MemCkeSetup [Auto]
MemCadBusClkDrvStren [Auto]
MemCadBusAddrCmdDrvStren [Auto]
MemCadBusCsOdtDrvStren [Auto]
MemCadBusCkeDrvStren [Auto]
Mem Over Clock Fail Count [Auto]
Voltage Monitor [Die Sense]
CPU Load-line Calibration [Auto]
CPU Current Capability [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Auto]
CPU Power Thermal Control [120]
VDDSOC Load-line Calibration [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Phase Control [Auto]
DRAM Current Capability [100%]
DRAM Power Phase Control [Extreme]
DRAM Switching Frequency [Auto]
CPU Core Current Telemetry [Auto]
CPU SOC Current Telemetry [Auto]
Force OC Mode Disable [Disabled]
SB Clock Spread Spectrum [Auto]
VTTDDR Voltage [Auto]
VPP_MEM Voltage [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
VDDP Voltage [Auto]
1.8V Standby Voltage [Auto]
CPU 3.3v AUX [Auto]
1.2V SB Voltage [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
PLL reference voltage [Auto]
T Offset [Auto]
Sense MI Skew [Auto]
Sense MI Offset [Auto]
Promontory presence [Auto]
Clock Amplitude [Auto]
CPU Core Voltage [Auto]
CPU SOC Voltage [Manual]
- VDDSOC Voltage Override [1.07500]
DRAM Voltage [1.45000]
VDDG CCD Voltage Control [0.925]
VDDG IOD Voltage Control [0.975]
CLDO VDDP Voltage [0.880]
1.00V SB Voltage [Auto]
1.8V PLL Voltage [Auto]
Security Device Support [Enable]
SHA-1 PCR Bank [Disabled]
SHA256 PCR Bank [Enabled]
Pending operation [None]
Platform Hierarchy [Enabled]
Storage Hierarchy [Enabled]
Endorsement Hierarchy [Enabled]
TPM 2.0 UEFI Spec Version [TCG_2]
Physical Presence Spec Version [1.3]
Disable Block Sid [Disabled]
Selects TPM device [Enable Firmware TPM]
Erase fTPM NV for factory reset [Enabled]
PSS Support [Enabled]
PPC Adjustment [PState 0]
NX Mode [Enabled]
SVM Mode [Disabled]
SMT Mode [Auto]
Core Leveling Mode [Automatic mode]
CCD Control [Auto]
SATA Port Enable [Enabled]
SATA Mode [AHCI]
NVMe RAID mode [Disabled]
SMART Self Test [Auto]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
HD Audio Controller [Enabled]
PCIEX16_1 Bandwidth Bifurcation configuration [Auto Mode]
PCIEX16_2 Bandwidth Bifurcation configuration [Auto Mode]
When system is in working state [All On]
Q-Code LED Function [POST Code Only]
When system is in sleep, hibernate or soft off states [All On]
Realtek 2.5G LAN Controller [Auto]
Intel LAN Controller [Auto]
ASM1074 Controller [Enabled]
Wi-Fi 6 (802.11ax) Controller [Enabled]
Bluetooth Controller [Enabled]
USB power delivery in Soft Off state (S5) [Enabled]
PCIEX16_1 Mode [Auto]
PCIEX16_2 Mode [Auto]
PCIEX1 Mode [Auto]
PCIEX16_3 Mode [Auto]
M.2_1 Link Mode [Auto]
M.2_2 Link Mode [Auto]
SB Link Mode [Auto]
ErP Ready [Disabled]
Restore AC Power Loss [Power Off]
Power On By PCI-E [Disabled]
Power On By RTC [Disabled]
Above 4G Decoding [Enabled]
Resize BAR Support [Auto]
SR-IOV Support [Disabled]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
HGST HTS721075A9E630 0 [Auto]
USB Device Enable [Enabled]
U32G2_2 [Enabled]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G1_10 [Enabled]
U32G1_11 [Enabled]
USB12 [Enabled]
USB13 [Enabled]
U32G2_7 [Enabled]
U32G2_8 [Enabled]
U32G2_C9 [Enabled]
Network Stack [Disabled]
Device [SATA6G_1: CT2000MX500SSD1]
CPU Temperature [Monitor]
CPU Package Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
T_Sensor Temperature [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
CPU Fan Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
Chassis Fan 3 Speed [Monitor]
High Amp Fan Speed [Monitor]
W_PUMP+ Speed [Monitor]
AIO PUMP Speed [Monitor]
Flow Rate [Monitor]
CPU Core Voltage [Monitor]
3.3V Voltage [Monitor]
5V Voltage [Monitor]
12V Voltage [Monitor]
CPU Fan Q-Fan Control [PWM Mode]
CPU Fan Step Up [0 sec]
CPU Fan Step Down [0 sec]
CPU Fan Speed Low Limit [200 RPM]
CPU Fan Profile [Manual]
CPU Fan Upper Temperature [60]
CPU Fan Max. Duty Cycle (%) [100]
CPU Fan Middle Temperature [50]
CPU Fan Middle Duty Cycle (%) [75]
CPU Fan Lower Temperature [35]
CPU Fan Min Duty Cycle (%) [60]
Chassis Fan 1 Q-Fan Control [PWM Mode]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Step Up [0 sec]
Chassis Fan 1 Step Down [0 sec]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Profile [Manual]
Chassis Fan 1 Upper Temperature [65]
Chassis Fan 1 Max. Duty Cycle (%) [100]
Chassis Fan 1 Middle Temperature [55]
Chassis Fan 1 Middle Duty Cycle (%) [80]
Chassis Fan 1 Lower Temperature [30]
Chassis Fan 1 Min Duty Cycle (%) [60]
Chassis Fan 2 Q-Fan Control [PWM Mode]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Step Up [0 sec]
Chassis Fan 2 Step Down [0 sec]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Profile [Manual]
Chassis Fan 2 Upper Temperature [65]
Chassis Fan 2 Max. Duty Cycle (%) [100]
Chassis Fan 2 Middle Temperature [55]
Chassis Fan 2 Middle Duty Cycle (%) [60]
Chassis Fan 2 Lower Temperature [35]
Chassis Fan 2 Min Duty Cycle (%) [40]
Chassis Fan 3 Q-Fan Control [PWM Mode]
Chassis Fan 3 Q-Fan Source [CPU]
Chassis Fan 3 Step Up [0 sec]
Chassis Fan 3 Step Down [0 sec]
Chassis Fan 3 Speed Low Limit [200 RPM]
Chassis Fan 3 Profile [Manual]
Chassis Fan 3 Upper Temperature [65]
Chassis Fan 3 Max. Duty Cycle (%) [100]
Chassis Fan 3 Middle Temperature [55]
Chassis Fan 3 Middle Duty Cycle (%) [60]
Chassis Fan 3 Lower Temperature [35]
Chassis Fan 3 Min Duty Cycle (%) [40]
High Amp Fan Q-Fan Control [Auto]
High Amp Fan Q-Fan Source [CPU]
High Amp Fan Step Up [0 sec]
High Amp Fan Step Down [0 sec]
High Amp Fan Speed Low Limit [200 RPM]
High Amp Fan Profile [Standard]
Water Pump+ Q-Fan Control [Disabled]
AIO Pump Q-Fan Control [Disabled]
Above 4GB MMIO Limit [39bit (512GB)]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Fast Boot]
Boot Logo Display [Auto]
Bootup NumLock State [On]
POST Delay Time [1 sec]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Force BIOS]
Interrupt 19 Capture [Disabled]
Setup Mode [Advanced Mode]
Launch CSM [Disabled]
OS Type [Windows UEFI mode]
AMI Native NVMe Driver Support [Enabled]
Flexkey [Reset]
Setup Animator [Disabled]
Load from Profile [1]
Profile Name [3733]
Save to Profile [1]
DIMM Slot Number [DIMM_A1]
Bus Interface [PCIEX16_1]
Download & Install ARMOURY CRATE app [Enabled]
CPU Frequency [0]
CPU Voltage [0]
CCD Control [Auto]
Core control [Auto]
SMT Control [Auto]
Overclock [Auto]
Power Down Enable [Auto]
Cmd2T [Auto]
Gear Down Mode [Auto]
CAD Bus Timing User Controls [Auto]
CAD Bus Drive Strength User Controls [Auto]
Data Bus Configuration User Controls [Auto]
Infinity Fabric Frequency and Dividers [Auto]
ECO Mode [Disable]
Precision Boost Overdrive [Advanced]
PBO Limits [Manual]
PPT Limit [W] [210]
TDC Limit [A] [155]
EDC Limit [A] [190]
Curve Optimizer [Per Core]
Core 0 Curve Optimizer Sign [Negative]
Core 0 Curve Optimizer Magnitude [25]
Core 1 Curve Optimizer Sign [Negative]
Core 1 Curve Optimizer Magnitude [25]
Core 2 Curve Optimizer Sign [Negative]
Core 2 Curve Optimizer Magnitude [25]
Core 3 Curve Optimizer Sign [Negative]
Core 3 Curve Optimizer Magnitude [25]
Core 4 Curve Optimizer Sign [Negative]
Core 4 Curve Optimizer Magnitude [25]
Core 5 Curve Optimizer Sign [Negative]
Core 5 Curve Optimizer Magnitude [23]
Core 6 Curve Optimizer Sign [Negative]
Core 6 Curve Optimizer Magnitude [20]
Core 7 Curve Optimizer Sign [Negative]
Core 7 Curve Optimizer Magnitude [27]
Core 8 Curve Optimizer Sign [Negative]
Core 8 Curve Optimizer Magnitude [27]
Core 9 Curve Optimizer Sign [Negative]
Core 9 Curve Optimizer Magnitude [27]
Core 10 Curve Optimizer Sign [Negative]
Core 10 Curve Optimizer Magnitude [27]
Core 11 Curve Optimizer Sign [Negative]
Core 11 Curve Optimizer Magnitude [27]
Core 12 Curve Optimizer Sign [Negative]
Core 12 Curve Optimizer Magnitude [27]
Core 13 Curve Optimizer Sign [Negative]
Core 13 Curve Optimizer Magnitude [27]
Core 14 Curve Optimizer Sign [Negative]
Core 14 Curve Optimizer Magnitude [27]
Core 15 Curve Optimizer Sign [Negative]
Core 15 Curve Optimizer Magnitude [27]
Max CPU Boost Clock Override [50MHz]
LN2 Mode [Auto]
SoC/Uncore OC Mode [Disabled]
VDDP Voltage Control [Auto]
VDDG Voltage Control [Auto]
NUMA nodes per socket [Auto]
LCLK DPM [Auto]
LCLK DPM Enhanced PCIe Detection [Auto]
Custom Pstate0 [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
Core Watchdog Timer Enable [Auto]
Global C-state Control [Disabled]
Power Supply Idle Control [Auto]
SEV ASID Count [Auto]
SEV-ES ASID Space Limit Control [Auto]
Streaming Stores Control [Auto]
Local APIC Mode [Auto]
ACPI _CST C1 Declaration [Auto]
MCA error thresh enable [Auto]
PPIN Opt-in [Auto]
Fast Short REP MOVSB [Enabled]
Enhanced REP MOVSB/STOSB [Enabled]
IBS hardware workaround [Auto]
DRAM scrub time [Auto]
Poison scrubber control [Auto]
Redirect scrubber control [Auto]
Redirect scrubber limit [Auto]
Memory interleaving [Auto]
Memory interleaving size [Auto]
1TB remap [Auto]
DRAM map inversion [Auto]
ACPI SRAT L3 Cache As NUMA Domain [Auto]
ACPI SLIT Distance Control [Auto]
ACPI SLIT remote relative distance [Auto]
GMI encryption control [Auto]
xGMI encryption control [Auto]
CAKE CRC perf bounds Control [Auto]
4-link xGMI max speed [Auto]
3-link xGMI max speed [Auto]
xGMI TXEQ Mode [Auto]
PcsCG control [Auto]
Disable DF to external downstream IP SyncFloodPropagation [Auto]
Disable DF sync flood propagation [Auto]
CC6 memory region encryption [Auto]
Memory Clear [Auto]
Overclock [Auto]
Disable Burst/Postponed Refresh [Auto]
DRAM Maximum Activate Count [Auto]
Cmd2T [Auto]
Data Poisoning [Auto]
DRAM Post Package Repair [Default]
RCD Parity [Auto]
DRAM Address Command Parity Retry [Auto]
Write CRC Enable [Auto]
DRAM Write CRC Enable and Retry Limit [Auto]
Disable Memory Error Injection [True]
DRAM ECC Symbol Size [Auto]
DRAM ECC Enable [Auto]
DRAM UECC Retry [Auto]
TSME [Auto]
Data Scramble [Auto]
DFE Read Training [Auto]
FFE Write Training [Auto]
PMU Pattern Bits Control [Auto]
MR6VrefDQ Control [Auto]
CPU Vref Training Seed Control [Auto]
Chipselect Interleaving [Auto]
BankGroupSwap [Auto]
BankGroupSwapAlt [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
Address Hash Rm [Auto]
SPD Read Optimization [Enabled]
MBIST Enable [Disabled]
Pattern Select [PRBS]
Pattern Length(VMR) [6]
Aggressor Channel [1 Aggressor Channel]
Aggressor Static Lane Control [Disabled]
Target Static Lane Control [Disabled]
Worst Case Margin Granularity [Per Chip Select]
Read Voltage Sweep Step Size [1]
Read Timing Sweep Step Size [1]
Write Voltage Sweep Step Size [1]
Write Timing Sweep Step Size [1]
IOMMU [Auto]
FCLK Frequency [Auto]
SOC OVERCLOCK VID [0]
UCLK DIV1 MODE [Auto]
SoC/Uncore OC Mode [Auto]
LN2 Mode [Auto]
ACS Enable [Auto]
PCIe ARI Support [Auto]
PCIe ARI Enumeration [Auto]
PCIe Ten Bit Tag Support [Auto]
cTDP Control [Auto]
EfficiencyModeEn [Auto]
Package Power Limit Control [Auto]
APBDIS [Auto]
DF Cstates [Disabled]
CPPC [Auto]
CPPC Preferred Cores [Auto]
NBIO DPM Control [Auto]
Early Link Speed [Auto]
Presence Detect Select mode [Auto]
Preferred IO [Auto]
CV test [Auto]
Loopback Mode [Auto]
SRIS [Auto]
Data Link Feature Exchange [Disabled]
And here are my settings from 3903:
[2021/12/03 11:05:51]
Core VID [Auto]
CCX0 Ratio [Auto]
CCX0 Ratio [Auto]
Trcdrd [15]
Trcdwr [15]
Trc [35]
TrrdS [4]
TrrdL [4]
Tfaw [16]
TwtrS [4]
TwtrL [8]
Twr [10]
Trcpage [Auto]
TrdrdScl [2]
TwrwrScl [2]
Trfc [243]
Trfc2 [Auto]
Trfc4 [Auto]
Tcwl [14]
Trtp [8]
Trdwr [8]
Twrrd [3]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
Tcke [Auto]
ProcODT [40 ohm]
Cmd2T [1T]
RttNom [Auto]
RttWr [Auto]
RttPark [Auto]
MemCkeSetup [Auto]
VDDP Voltage [Auto]
CPU 3.3v AUX [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
PLL Tune R1 [Auto]
T Offset [Auto]
NX Mode [Enabled]
SVM Mode [Disabled]
SMT Mode [Auto]
CCD Control [Auto]
SATA Mode [AHCI]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
PCIEX1 Mode [Auto]
SB Link Mode [Auto]
U32G2_2 [Enabled]
U32G2_3 [Enabled]
U32G2_4 [Enabled]
U32G1_10 [Enabled]
U32G1_11 [Enabled]
USB12 [Enabled]
USB13 [Enabled]
U32G2_7 [Enabled]
U32G2_8 [Enabled]
U32G2_C9 [Enabled]
Flow Rate [Monitor]
Fast Boot [Enabled]
Flexkey [Reset]
Profile Name [3733]
Save to Profile [1]
CPU Frequency [0]
CPU Voltage [0]
CCD Control [Auto]
Core control [Auto]
SMT Control [Auto]
Overclock [Auto]
Cmd2T [Auto]
ECO Mode [Disable]
PBO Limits [Manual]
PPT Limit [W] [210]
TDC Limit [A] [160]
EDC Limit [A] [190]
Core 0 Curve Optimizer Magnitude [30]
Core 1 Curve Optimizer Magnitude [30]
Core 2 Curve Optimizer Magnitude [30]
Core 3 Curve Optimizer Magnitude [30]
Core 4 Curve Optimizer Magnitude [30]
Core 5 Curve Optimizer Magnitude [28]
Core 6 Curve Optimizer Magnitude [25]
Core 7 Curve Optimizer Magnitude [30]
Core 8 Curve Optimizer Magnitude [30]
Core 9 Curve Optimizer Magnitude [30]
Core 10 Curve Optimizer Magnitude [30]
Core 11 Curve Optimizer Magnitude [30]
Core 12 Curve Optimizer Magnitude [30]
Core 13 Curve Optimizer Magnitude [30]
Core 14 Curve Optimizer Magnitude [30]
Core 15 Curve Optimizer Magnitude [30]
CPU Boost Clock Override [Enabled (Positive)]
Max CPU Boost Clock Override (+) [50]
LN2 Mode [Auto]
LCLK DPM [Auto]
PPIN Opt-in [Auto]
1TB remap [Auto]
Memory Clear [Auto]
Overclock [Auto]
Cmd2T [Auto]
RCD Parity [Auto]
TSME [Auto]
IOMMU [Auto]
LN2 Mode [Auto]
ACS Enable [Auto]
cTDP Control [Auto]
APBDIS [Auto]
CPPC [Auto]
Preferred IO [Auto]
CV test [Auto]
SRIS [Auto]
As you can see, everything is identical except that I'm able to run a much more aggressive CO on 3903! It's a bummer my chip seems to be bronze tier because I can't really break 5075 SC but I'll take the low temps straight to the bank!
