And RAM OC is the next step ahead!R23 don’t really care about ram.
I've started over with a new kit but I'm struggling a little:
A guide to ram overclocking on Zen 3 | Page 4 | Overclock.net
Baio
Thanks, I'm gonna try +100.Try +100 instead of +200.
With your cooling might benefit from even lower tdc and edc. R23 isn’t really heavy on amps.
You just said you ran with lots of processes in the background - so no then I don't have any tips because there is nothing to compare against. You can't optimize any limit or value if you have a billion random parameters dirtying up the results.Thanks, I'm gonna try +100.
Any tip for lower TDC and EDC?
Baio
I noticed it on some of the AGESA 1.2.0.7 upgrades I did, for me it's not a biggie though as by now I know most if not all bios settings from memory.Did you guys lose ability to load saved setting from USB after updating to 4201? Sooo not happy right now. All settings from scratch cause they won’t load. “Not for this cpu family”
Yeah the problem is I had to redo my fan profiles in BIOS. Luckily fan xpert didn't eat them this time (though I have backups). I've had it reset its base profiles before. Well, it did this time as well but still saw my saved ones. I just had to set the temp source back to the water temp sensors again. I really didn't want to have to redo profiles for the fans on my loop.I noticed it on some of the AGESA 1.2.0.7 upgrades I did, for me it's not a biggie though as by now I know most if not all bios settings from memory.
Different thing with my Z690 rig, a lot of memory settings I'm not familiar with have to thread carefully LoL
Glad it works for you. On my side after we got cppc support in bios. The default aggressive only worked with cppc off. Eff aggressive with cppc on boosted based on ranking and scheduled threads properly with my 3900x and 5900x.I don't understand exactly which point you are referring to.
If you disable all the CPPC settings, you will get less performances because the OS doesn't know anymore which core relates to which CCX cache, so it can't group threads that work on the same set of data to the cores that use the same cache, and this will inherently slow down cpu heavy algorithms as accessing the cache of a different CCX has a big performance penalty.
The processor performance boost mode is a setting that defines the speed with which a core will increase its frequency up to the maximum turbo boost mhz when a thread with a heavy workload requires it.
When CPPC is OFF, the CPU will use the P-states to manage each core frequency, and the P-states allow only two possible frequency states: Turbo boost ON, and Turbo boost OFF. So the "Aggressive" setting will be mapped to "Turbo boost ON immediately" and the "Efficient" setting will be mapped to "Turbo boost ON only if the thread specifically ask for the turbo frequency".
When CPPC is ON, the CPU has more granularity to choose the target core frequency, so the "aggressive" setting will be mapped to "Turbo boost ON immediately" and the "Efficient" setting will be mapped to "Start at an OS-calculated frequency and progressively increase up to theTurbo boost frequency".
All the options in that list are always mapped to one of the available choices following this table:
There isn't one of those listed choices that is not "functional" if CPPC is ON or OFF. In Windows 11 the default for both the "balanced" and "high performance" profiles is to use "Aggressive" as boost mode and I didn't get any performance increase by using a different value (I got performance increases by changing other power profile settings unrelated to CPPC).
But the performance penalty that you get if you disable CPPC is not related to the frequency of the cores. It's related to the ability of the cores on the same CCX to access the same cache instead of having to do an extra roundtrip to access the cache on the other CCX. Without knowing which cores are in which CCX , the OS can't optimize this cache access strategy.
L1,L2 prefetch off reporting better latency in Aida64 is not accurate or representative of real usage.With my 5950X, I finally can boot at RAM 4000MHz/2000MHz.
This was impossible with my former 5900X.
I also set my best optimized primary and secondary timings in order to boot.
Aida64 (L1 + L2 HW Prefetcher disabled, which provided better latency but lower Memory Read/Write/copy values) :
I could pass 1 hour KArhu's (1800%), as a first shot for stability.
Of course this is not enough and I will test it overnight to confirm stability.
BUT...This is Whea 19 fest....
I installed Whea suppressor service from @ManniX-ITA.
Let's see how things go in the next days.
Have you tried DDR4 4000 - GDM off, CL15, T2 ?
@J7SCL1,L2 prefetch off reporting better latency in Aida64 is not accurate or representative of real usage.
here's what it came out with when I tested aida64 yesterday.
l1,l2 on
4000cl16 with no apps open 53.2ns, open a few apps and latency climbs to 53.4ns on repeated runs
l1,l2 off
4000cl16 with no apps open 53.0ns, open a few apps and latency climbs to 54ns on repeated runs
and -700MB/s bandwith loss
this makes sense because once you have more than one program/process active dealing with memory you need prefetch active to get good bandwhith / latency response from the memory side
this also shows as less smooth fps in heavy games
No, still Vid=1.425V if EDC>140Amps.Have they fixed (4201 the EDC limit yet? Just tried 145EDC and Ryzen master is showing that limit.
I fixed those crashes in games by raising PLL from 1.9V to 1.95V.@J7SC
CL15, 2T => no boot, even with [email protected]
I don't want ot tweak again all timings and voltages
With L1 + L2 auto :
But with this memory OC, I had to tweak again all my CO curve as it crashes or WHEA 18 like hell in gaming.
conclusion : if I use this nice memory OC in gaming with L1 + L2 HW auto, as I had to add voltages through CO to all my cores, I have now poor single core performance, but very nice memory and cache Bandwith and latencies.
Probably makes more sense to look at effective core speeds...below is an oldie on nominal ones which at the end of the day don't mean that much...Glad it works for you. On my side after we got cppc support in bios. The default aggressive only worked with cppc off. Eff aggressive with cppc on boosted based on ranking and scheduled threads properly with my 3900x and 5900x.
Always have hwinfo open on my 2nd screen, aggressive (default) doesn't boost very well on dual ccds. It's only 1 to 4 cores randomly (ccd0 or ccd1) being loaded vs having ccd0 boosted on ranks then moves to 1-2 cores from ccd1.
This is with normal light games, heavy threaded games will trigger all cores to boost.
Here's good scaling for core boost / thread scheduling(~86w with Destiny2 at 4k) which I don't get with aggressive default.
This statement makes no sense. Explain, if you think you know what you are talking about.this makes sense because once you have more than one program/process active dealing with memory you need prefetch active to get good bandwhith / latency response from the memory side
Whenever you have any apps running, benchmarks are gonna get worse. Try R23, y-cruncher, anything, open apps slow things,L1,L2 prefetch off reporting better latency in Aida64 is not accurate or representative of real usage.
l1,l2 on
l1,l2 off
Well, the latest BIOS is supposed to fix fTPM issues... You should take screenshots of your 3302 BIOS settings, and update to the latest BIOS, reset everything to optimized defaults, and see how you get on.I am having problems with fTPM...lots of stuttering when enabled but I can't play games such as Valorant if I disable fTPM because they need to have fTPM enabled...
220Thanks, I'm gonna try +100.
Baio
