1 - 20 of 119 Posts
Meddling user
Discussion Starter · #1 · (Edited)
Last update date:- 23/06/19
Last 3 updates:-
  1. FAQ has info on using Flashback feature.
  2. Added photos of TIM spread from EK/Bykski block when removed from ZE.
  3. Further 3400MHz C15 1T test data plus add some of my builds info in OP.
ASUS ROG Zenith Extreme Alpha X399
Overclocking/Support
Disclosure:-
The board is supplied to me by ASUS as a sample, it is a full retail sample from what I can tell. I have had the motherboard since early March 2019. Due to unforeseen circumstances I did not get to use it until recently.
Nothing has been stated to me on what I can or can not do with it, say about it, etc. Any thing by me within this thread are my own opinions and shares as I would do if I had purchased the motherboard. OP is constructed as I wish plus on how the thread evolves/needs of it for my own and other fellow owners.
ASUS WMI
The ZEA still uses ITE8665E as it's Super IO chip. The ASUS WMI allows SW to access it without it being adversely affected, which could lead to fan header PWM issues, stuck monitoring data, etc. This solution only works if the SW accessing SIO uses ASUS WMI.
So far I have used HWiNFO and multiple instances of CPU-Z concurrently, without issues. Hoping to try more tests, etc and share info ASAP.
Intel AC 9260 (9260NGW)
At present I am reusing W10 install I had used on Zenith Extreme. I had uninstalled the Qualcomm Atheros drivers prior to firing OS up on Zenith Extreme Alpha. I had bugcode NDIS driver check IIRC, only way to gain access to OS was to disable the onboard Intel AC 9260 WiFi, install drivers from support USB in box, then re-enable AC 9260.
The drivers off of support USB worked poorly for me, I managed only to gain access to my mobile phone WiFi hotspot, only way to get better functionality was to install the latest drivers from Intel site.
Thoughts on Zenith Extreme Alpha coming from Zenith Extreme
The Zenith Extreme was the weightiest board I'd ever had, but the Alpha seems even more heavier. I did not have the time to weigh each board. I will weigh the ZE now, ZEA when remove it and update this section.
I had to do minimal changes to cable routing, only real change I had to make was the 2x 8pin CPU cables. Connection location is pretty much same, but as orientation differs I had to reroute cables due to that.
The mirror effect on the IO cover/OLED looks really nice IMO, gawped at it a while before firing her up for the first time :) . I don't think the OLED screen is any larger, but I reckon the text is improved on sizing and perhaps bolder than on ZE. Only use for me is how the Q-Codes at POST have some text with them and at times I will ref the CPU temp when don't have SW monitoring running in normal use. Even though it can be customised for logo, etc, I never really changed anything on it on ZE and don't think I will on ZEA.
Due to the larger VRM cooling solution on the the ZEA, I was unable to access the 2nd screw hole on top row, I still used a stand off on mobo tray.
Also due to the size of the VRM, the CPU socket, RAM slots, addon card slots have moved down the board and a slot has been lost plus 4 dual slot GPU would be an issue.
The changes are not an issue for me, I much prefer the meatier VRM for use with Threadripper :D . SOC phases have also increased from 3 to 4, improved components, besides being linked to passive cooling solution of chipset.
The ZEA uses 8 true phases over 16 power stages, it's like a doubled setup, but does not uses doublers.
Der8auer also has this great video on YT about the new setup and compared to a ZEA with doublers.
The ZEA has dual bios besides "Flashback" feature. Switching between bios chip is done via a push button on lower right of motherboard, the corresponding LED will be lit (just below CPU socket) to denote which chip is in use.
Both the ZE and ZEA had Foxconn sockets, I have had no issues with either board. On ZEA I even did not use the torque tool, but just used a normal T20 bit in screwdriver and tightened down each screw snug and system POST'ed 1st time without issues.
My TIM spread results
TIM I have always spread by hand using a strip cut from plastic card. Below is original EK TR block and Bykski A-Ryzen-ThV2-X when removed from ZE, AS5 was used. Reckon I could cut back on TIM amount used, currently been using ~4-5 times more bigger sized blob than on say AM4 CPU.
PMU Training menu
Besides access to the usual set of options to gain memory stability Threadripper allows tinkering with PMU training aka IMC training :) . See this post by Elmor for further info.
I transferred a 1950X to ZEA, which I've had since launch. I used the same RAM kit as on ZE, F4-3200C14Q-32GTZSW. I expected the same RAM MHz/timings to work with ease. Initially testing showed it did, as I spent more time rerunning tests I have found I needed to tinker with the PMU menu if I wanted to keep same RAM MHz/timings, below is currently what I'm using for 3400MHz C15 1T.
Elmor shared information on these settings in the Zenith Extreme thread.
The PMU training options have been present on X399 since TR2 was launched.
FFE/DFE: http://emlab.uiuc.edu/ece546/Lect_27.pdf . Not clear what's a better combination of Enabled/Disabled, will depend on the board and modules used.
PMU Pattern Bits decides how many bits are used for the memory training pattern. A higher value (up to "A" = 10 in hex) will cause training to take longer, but also yield a better result. IIRC the default is 4.
Here is a link to an Imgur album showing the ~18hrs testing to validate the ZEA is capable of running same RAM MHz/timings as I did on ZE with same CPU/RAM. Order of images is first test at top, settings used txt on Pastebin.
After the tests of Kahru RAM Test on various POST methods of board I've done P95 v28.10b1 & v29.4b4 set to 8K 4096K 27GB. v28.10b1 ~7hrs, PWM check, v29.4b4 ~9hrs, PWM check, Y-Cruncher ~4hrs, PWM check, RB ~1hr, testing totalled ~25hrs continuous.
Room ambient temp: ~24C
P95 v28.10b1 RAM Offset 0mV 1.056 1.355 60 On Off 5 room 25.5C 24.8C 23.6C PASS 7hrs.jpg
P95 v29.4b8 RAM Offset 0mV 1.056 1.355 60 On Off 5 room 24.1C 24.6C PASS 9hrs.jpg
Note: averages incorrect in RB screenie as I forgot to capture screenie at test end and let monitoring over run.
*** more content to be added ***
My ZEA Build info
CPU: Threadripper 1950X
RAM: F4-3200C14Q-32GTZSW
GPU: Reference Radeon Vega 64
Storage: 1x Intel 660P 1TB NVME, 2x Crucial MX100 256GB SATA SSD, 2x 2TB SATA HDD
Cooling: Bykski A-Ryzen-ThV2-X, EK-FC Radeon Vega, 2x Magicool 360 G2 Slim radiators, 6x Artic Cooling F12 PWM, 1x Slient Wings 3 140mm 1000rpm, EK-XRES Revo 140 D5 PWM, Barrow fittings, EK ZMT 16/10, Mayhems XT-1 Clear concentrate ~20% with distilled water.
Case: Be Quiet Dark Base 900, removed front door and added mesh, top of chassis where it meet top panel any cutouts have been taped up so no back draft air from top rad fans re-enters case, top panel had plastic removed where mesh is to allow better air flow.
Power supply: Cooler Master V850
Other info: Used Arctic Silver 5 on CPU, evenly spread using plastic card by hand. The Bykski block has simple screw down mount, no springs, etc. The motherboard controls all fans/pump via UEFI profile, based on water temperature. Front rad fans are mounted on rad outer face as intakes. Top rad fans are mounted on rad inner face as exhaust. Each set of rad fans uses it's own 4 in 1 cable, powered by molex. Loop order is res/pump > GPU block > CPU block > Top rad > Front rad. Only RGB used is default board and CPU block non addressable 4 pin.
OS: Windows 10 Pro, Linux Mint v19
Quirk noted in UEFI 0207/0405
My board came with UEFI 0207 out of the box, I opted to install 0405 via flashback after initial POST of board. I had noted CB15 was giving higher score for multithread. Upon checking further I noted the CPU was sticking to 3.7GHz all cores boost for even loads it should not. Below image has same CPU/RAM on ZE UEFI 1701 compared to ZEA UEFI 0405/0207.
The work around that allows the Threadripper 1950X I have to work for boost frequencies on ZEA UEFI 0207/0405 as it should is to place CPU core voltage mode in offset mode/positive/auto, defaults to 0mV offset ref Turbo V in screenies.
FAQ
*** More info to be added ***
UEFI Flashback
i) Rename flash filename as ZEA.CAP, copy to USB stick root.
ii) Make sure USB stick is in Flashback port (marked in red box below image)
iii) Press and hold the Flashback button (blue box, above image) ~5secs. Blue LED on the button will flash slow for a few seconds and quicken as it starts update process. At the end of process it will extinguish, you are ready to boot up. If the blue LED stays constant the UEFI file was not found on USB stick, so check USB stick is correct format and filename is correct.
http://event.asus.com/2012/mb/USB_BIOS_Flashback_GUIDE/
Note: Flashback is hardware flash tool built onto mobo, you can even use this feature with no CPU/RAM/GPU, etc, only power to board.
Links
Product Links
Product page, link.
Support page, link.
Reviews
KoolShare review, link (IIRC first one on web).
TweakTown review, link
Utilities
ASUS TurboV Core v1.02.02
Ryzen Timing Checker
DRAM Calculator for Ryzen
GSAT for Linux
Useful sites
Ram Latency Calculator
Meddling user
Meddling user
Discussion Starter · #4 · (Edited)
1. I currently only use RGB which is on board plus a Bykski block. The block uses non addressable RGB. Board and block tested for at stock "Rainbow" and static "Red", so far no issues. I can't see me adding more RGB as this is more than ample for me.
2. I may have missed PME training, if you mean PMU training it is the IMC training (Integrated Memory Controller). IMO what settings you may need would depend on HW in use, targetted settings.
3. I don't run Aura all the time, I tend to set RGB as I'd like, uninstall it (well revert to OS image without it) and board remembers the settings I use. In the past when I tested certain profiles of RGB all will not be remembered by board, so the OS SW is needed for them to function. If this has changed I do not know. When I tested RGB profiles in the past on it was for another aspect. If I have time I will try again some tests.
My board does not remember RGB settings on addressable connections and RAM, It does remember of 5V and OoBoard rgb configurations even with S3+S5 settings.
I cannot boot my mobo if I set erp modes to anything else then S3+S5. In S3+S5 mode it always shutdows and perform "dual boot" untill it finally boots. I use S3+S5 to keep off all RGB when board in shut down.
Rencently I started to have issue that board does not boot until I pull battery complexly and reinsert it after some times. Not sure what is that all about.. It is just stuck on code 00. I see it happening on the new BIOS i never had this issue on the old one.
PMU training by default is set to Auto i tried to set it to Enable, but it does not have any additional affect.
I see flickering of RGB when i am playing a game or something .. I have 1000W PSU and 2080ti i wonder if I 'm pulling more then that which makes PSU uncomfortable ;-(
Edit:
One more issue i remember LiveDash sometimes just stops especially when heavy CPU load is involved. Restarts serveices in windows does not help. Only full cold PC restart bring LiveDash to live.
Meddling user
Discussion Starter · #6 ·
Sorry I don't have access to any addressable RGB items, nor RGB RAM, hopefully another owner can comment.
To have RGB off on shutdown I use setting:-
When system is in sleep, hibernate or soft off states [Aura Off]
Found on Advanced > Onboard Devices Configuration.
This "dual boot" maybe down to another issue. Perhaps share a UEFI settings txt and hardware being used. I have added in OP info on my system so gives better context for test data, etc I'm sharing.
I use a Cooler Master V850 for my setup, peak watts I've seen on my wall meter IIRC is ~750W if CPU & GPU OC'd when under high load. As decent power supplies are rated on PC side I am well within it's capabilities to function without issue. Perhaps gain a wall meter plug.
I do reference OLED on mobo at times, I have not noted it go off or have an issue. Currently it is set as it would be from factory, I have not installed any OS SW relating to it either. I added further test data, where rig had been under heavy load for over ~24hrs continuously.
Meddling user
Discussion Starter · #8 ·
I've added most of my thoughts on ZE vs ZEA in OP. So far in usage and performance seems the same, except VRM temps are improved. I've only had the fans on VRM come on once, did not even know they were on until saw the reading in HWINFO. I did capture a video of them which I will place in OP soon. All the did was come on momentarily and turn off again, this was with 3.9GHz OC on 1950X, loaded with P95.
UEFI is exactly the same besides some new options for things like controlling PSU fans which use the "Node" connector.
Could someone capture IOMMU groups and lstopo of this board with all populated PCIE devices, so we know what NUMA goes to which PCIE/RAM sticks?
Meddling user
Discussion Starter · #11 ·
Meddling user
Not a bug, but a feature
'[[email protected] ~]$ sudo lspci -vnn | grep 0a:00.0
0a:00.0 Non-Volatile memory controller [0108]: Device [1cc1:8201] (rev 03) (prog-if 02 [NVM Express])'
Having been having trouble with IOMMU on ZEA. On Arch Linux and I left pc overnight and got a bunch of AMD-VI issues with callback being ignored (and page mapping). Checked for issues on my raid and 0 errors were reported. When looking for the device causing the error the above showed. This is worrisome to say the least. I chose to enable "iommu=soft" so the pci-e can be allocated by software.
Well i there is some issues with IOMMU..
Slot 1 is invisible to IOMMU ... i posted this already on asus forums and level 1. This board looks bad ;-(
i have put some cards into my PCIE slots, including my primary 2080ti in slot 1 and GR710 into slot 3.
For some reason i don’t see my primary graphic cards in any iommu groups. It also does not show up in my bios, not sure if those things are connected.
Card works perfect under windows and under linux, so ***?
Is this Asus issue ?
[email protected]:~# find /sys/kernel/iommu_groups/ -type l
/sys/kernel/iommu_groups/17/devices/0000:09:00.0
/sys/kernel/iommu_groups/7/devices/0000:00:03.1
/sys/kernel/iommu_groups/25/devices/0000:0e:00.2
/sys/kernel/iommu_groups/15/devices/0000:00:19.6
/sys/kernel/iommu_groups/15/devices/0000:00:19.4
/sys/kernel/iommu_groups/15/devices/0000:00:19.2
/sys/kernel/iommu_groups/15/devices/0000:00:19.0
/sys/kernel/iommu_groups/15/devices/0000:00:19.7
/sys/kernel/iommu_groups/15/devices/0000:00:19.5
/sys/kernel/iommu_groups/15/devices/0000:00:19.3
/sys/kernel/iommu_groups/15/devices/0000:00:19.1
/sys/kernel/iommu_groups/5/devices/0000:00:02.0
/sys/kernel/iommu_groups/23/devices/0000:0d:00.3
/sys/kernel/iommu_groups/13/devices/0000:00:14.3
/sys/kernel/iommu_groups/13/devices/0000:00:14.0
/sys/kernel/iommu_groups/3/devices/0000:00:01.3
/sys/kernel/iommu_groups/21/devices/0000:0d:00.0
/sys/kernel/iommu_groups/11/devices/0000:00:08.0
/sys/kernel/iommu_groups/1/devices/0000:00:01.1
/sys/kernel/iommu_groups/18/devices/0000:0a:00.0
/sys/kernel/iommu_groups/8/devices/0000:00:04.0
/sys/kernel/iommu_groups/26/devices/0000:0e:00.3
/sys/kernel/iommu_groups/16/devices/0000:03:00.0
/sys/kernel/iommu_groups/16/devices/0000:02:00.0
/sys/kernel/iommu_groups/16/devices/0000:08:00.0
/sys/kernel/iommu_groups/16/devices/0000:01:00.2
/sys/kernel/iommu_groups/16/devices/0000:02:03.0
/sys/kernel/iommu_groups/16/devices/0000:01:00.0
/sys/kernel/iommu_groups/16/devices/0000:07:00.0
/sys/kernel/iommu_groups/16/devices/0000:02:09.0
/sys/kernel/iommu_groups/16/devices/0000:06:00.0
/sys/kernel/iommu_groups/16/devices/0000:02:02.0
/sys/kernel/iommu_groups/16/devices/0000:05:00.0
/sys/kernel/iommu_groups/16/devices/0000:01:00.1
/sys/kernel/iommu_groups/16/devices/0000:02:01.0
/sys/kernel/iommu_groups/16/devices/0000:02:04.0
/sys/kernel/iommu_groups/6/devices/0000:00:03.0
/sys/kernel/iommu_groups/24/devices/0000:0e:00.0
/sys/kernel/iommu_groups/14/devices/0000:00:18.3
/sys/kernel/iommu_groups/14/devices/0000:00:18.1
/sys/kernel/iommu_groups/14/devices/0000:00:18.6
/sys/kernel/iommu_groups/14/devices/0000:00:18.4
/sys/kernel/iommu_groups/14/devices/0000:00:18.2
/sys/kernel/iommu_groups/14/devices/0000:00:18.0
/sys/kernel/iommu_groups/14/devices/0000:00:18.7
/sys/kernel/iommu_groups/14/devices/0000:00:18.5
/sys/kernel/iommu_groups/4/devices/0000:00:01.5
/sys/kernel/iommu_groups/22/devices/0000:0d:00.2
/sys/kernel/iommu_groups/12/devices/0000:00:08.1
/sys/kernel/iommu_groups/2/devices/0000:00:01.2
/sys/kernel/iommu_groups/20/devices/0000:0c:00.0
/sys/kernel/iommu_groups/20/devices/0000:0c:00.1
/sys/kernel/iommu_groups/10/devices/0000:00:07.1
/sys/kernel/iommu_groups/0/devices/0000:00:01.0
/sys/kernel/iommu_groups/19/devices/0000:0b:00.0
/sys/kernel/iommu_groups/9/devices/0000:00:07.0
[email protected]:~# lspci
00:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
00:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit
00:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:01.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:01.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:01.3 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:01.5 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
00:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
00:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
00:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
00:14.0 SMBus: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller (rev 59)
00:14.3 ISA bridge: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge (rev 51)
00:18.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
00:18.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
00:18.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
00:18.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
00:18.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
00:18.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
00:18.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
00:18.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
00:19.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
00:19.1 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
00:19.2 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
00:19.3 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
00:19.4 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
00:19.5 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
00:19.6 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
00:19.7 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
01:00.0 USB controller: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset USB 3.1 xHCI Controller (rev 02)
01:00.1 SATA controller: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset SATA Controller (rev 02)
01:00.2 PCI bridge: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset PCIe Bridge (rev 02)
02:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:01.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:02.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:03.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:04.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
02:09.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port (rev 02)
03:00.0 Network controller: Intel Corporation Wireless-AC 9260 (rev 29)
05:00.0 Ethernet controller: Intel Corporation I211 Gigabit Network Connection (rev 03)
06:00.0 SATA controller: ASMedia Technology Inc. ASM1062 Serial ATA Controller (rev 02)
07:00.0 USB controller: Renesas Technology Corp. uPD720201 USB 3.0 Host Controller (rev 03)
08:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
09:00.0 Ethernet controller: Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion] (rev 02)
0a:00.0 USB controller: ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
0b:00.0 Non-Volatile memory controller: Sandisk Corp WD Black 2018/PC SN720 NVMe SSD
0c:00.0 VGA compatible controller: NVIDIA Corporation GK208B [GeForce GT 710] (rev a1)
0c:00.1 Audio device: NVIDIA Corporation GK208 HDMI/DP Audio Controller (rev a1)
0d:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 145a
0d:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
0d:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
0e:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 1455
0e:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
0e:00.3 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller
40:00.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
40:00.2 IOMMU: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit
40:01.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:02.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:03.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:03.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge
40:04.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:07.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:07.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
40:08.0 Host bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
40:08.1 PCI bridge: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B
41:00.0 VGA compatible controller: NVIDIA Corporation GV102 (rev a1)
41:00.1 Audio device: NVIDIA Corporation TU102 High Definition Audio Controller (rev a1)
41:00.2 USB controller: NVIDIA Corporation TU102 USB 3.1 Controller (rev a1)
41:00.3 Serial bus controller [0c80]: NVIDIA Corporation TU102 UCSI Controller (rev a1)
42:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 145a
42:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
42:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
43:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 1455
43:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
[email protected]:~# lspci -tvv
-+-[0000:40]-+-00.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
 |           +-00.2  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) I/O Memory Management Unit
 |           +-01.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           +-02.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           +-03.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           +-03.1-[41]--+-00.0  NVIDIA Corporation GV102
 |           |            +-00.1  NVIDIA Corporation TU102 High Definition Audio Controller
 |           |            +-00.2  NVIDIA Corporation TU102 USB 3.1 Controller
 |           |            \-00.3  NVIDIA Corporation TU102 UCSI Controller
 |           +-04.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           +-07.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           +-07.1-[42]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 145a
 |           |            +-00.2  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
 |           |            \-00.3  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
 |           +-08.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge
 |           \-08.1-[43]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 1455
 |                        \-00.2  Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
 \-[0000:00]-+-00.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Root Complex
             +-01.1-[01-08]--+-00.0  Advanced Micro Devices, Inc. [AMD] X399 Series Chipset USB 3.1 xHCI Controller
             |               +-00.1  Advanced Micro Devices, Inc. [AMD] X399 Series Chipset SATA Controller
             |               \-00.2-[02-08]--+-00.0-[03]----00.0  Intel Corporation Wireless-AC 9260
             |                               +-01.0-[04]--
             |                               +-02.0-[05]----00.0  Intel Corporation I211 Gigabit Network Connection
             |                               +-03.0-[06]----00.0  ASMedia Technology Inc. ASM1062 Serial ATA Controller
             |                               +-04.0-[07]----00.0  Renesas Technology Corp. uPD720201 USB 3.0 Host Controller
             |                               \-09.0-[08]----00.0  ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
             +-01.2-[09]----00.0  Aquantia Corp. AQC107 NBase-T/IEEE 802.3bz Ethernet Controller [AQtion]
             +-01.3-[0a]----00.0  ASMedia Technology Inc. ASM2142 USB 3.1 Host Controller
             +-01.5-[0b]----00.0  Sandisk Corp WD Black 2018/PC SN720 NVMe SSD
             +-03.1-[0c]--+-00.0  NVIDIA Corporation GK208B [GeForce GT 710]
             |            \-00.1  NVIDIA Corporation GK208 HDMI/DP Audio Controller
             +-07.1-[0d]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 145a
             +-08.1-[0e]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 1455
             |            +-00.2  Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode]
             |            \-00.3  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller
             +-14.0  Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller
             +-14.3  Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge
             +-18.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
             +-18.1  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
             +-18.2  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
             +-18.3  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
             +-18.4  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
             +-18.5  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
             +-18.6  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
             +-18.7  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
             +-19.0  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0
             +-19.1  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1
             +-19.2  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2
             +-19.3  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3
             +-19.4  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4
             +-19.5  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5
             +-19.6  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6
             \-19.7  Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7
https://forum.level1techs.com/upload...3b5e8d5d0.jpeg
https://forum.level1techs.com/upload...ef99549b5.jpeg
Meddling user
Discussion Starter · #16 · (Edited)
Linux n00b here.
UEFI Screenies
Terminal output as MacMus did.
[email protected] ~ $ find /sys/kernel/iommu_groups/ -type l
/sys/kernel/iommu_groups/17/devices/0000:0b:00.0
/sys/kernel/iommu_groups/35/devices/0000:43:00.1
/sys/kernel/iommu_groups/7/devices/0000:00:07.0
/sys/kernel/iommu_groups/25/devices/0000:40:03.0
/sys/kernel/iommu_groups/15/devices/0000:09:00.0
/sys/kernel/iommu_groups/33/devices/0000:42:00.0
/sys/kernel/iommu_groups/5/devices/0000:00:03.0
/sys/kernel/iommu_groups/23/devices/0000:40:01.0
/sys/kernel/iommu_groups/13/devices/0000:00:19.6
/sys/kernel/iommu_groups/13/devices/0000:00:19.4
/sys/kernel/iommu_groups/13/devices/0000:00:19.2
/sys/kernel/iommu_groups/13/devices/0000:00:19.0
/sys/kernel/iommu_groups/13/devices/0000:00:19.7
/sys/kernel/iommu_groups/13/devices/0000:00:19.5
/sys/kernel/iommu_groups/13/devices/0000:00:19.3
/sys/kernel/iommu_groups/13/devices/0000:00:19.1
/sys/kernel/iommu_groups/31/devices/0000:40:08.1
/sys/kernel/iommu_groups/3/devices/0000:00:01.5
/sys/kernel/iommu_groups/21/devices/0000:0c:00.2
/sys/kernel/iommu_groups/11/devices/0000:00:14.3
/sys/kernel/iommu_groups/11/devices/0000:00:14.0
/sys/kernel/iommu_groups/38/devices/0000:44:00.3
/sys/kernel/iommu_groups/28/devices/0000:40:07.0
/sys/kernel/iommu_groups/18/devices/0000:0b:00.2
/sys/kernel/iommu_groups/36/devices/0000:44:00.0
/sys/kernel/iommu_groups/8/devices/0000:00:07.1
/sys/kernel/iommu_groups/26/devices/0000:40:03.1
/sys/kernel/iommu_groups/16/devices/0000:0a:00.0
/sys/kernel/iommu_groups/34/devices/0000:43:00.0
/sys/kernel/iommu_groups/6/devices/0000:00:04.0
/sys/kernel/iommu_groups/24/devices/0000:40:02.0
/sys/kernel/iommu_groups/14/devices/0000:03:00.0
/sys/kernel/iommu_groups/14/devices/0000:02:00.0
/sys/kernel/iommu_groups/14/devices/0000:08:00.0
/sys/kernel/iommu_groups/14/devices/0000:01:00.2
/sys/kernel/iommu_groups/14/devices/0000:02:03.0
/sys/kernel/iommu_groups/14/devices/0000:01:00.0
/sys/kernel/iommu_groups/14/devices/0000:02:09.0
/sys/kernel/iommu_groups/14/devices/0000:06:00.0
/sys/kernel/iommu_groups/14/devices/0000:02:02.0
/sys/kernel/iommu_groups/14/devices/0000:01:00.1
/sys/kernel/iommu_groups/14/devices/0000:02:01.0
/sys/kernel/iommu_groups/14/devices/0000:02:04.0
/sys/kernel/iommu_groups/32/devices/0000:41:00.0
/sys/kernel/iommu_groups/4/devices/0000:00:02.0
/sys/kernel/iommu_groups/22/devices/0000:0c:00.3
/sys/kernel/iommu_groups/12/devices/0000:00:18.3
/sys/kernel/iommu_groups/12/devices/0000:00:18.1
/sys/kernel/iommu_groups/12/devices/0000:00:18.6
/sys/kernel/iommu_groups/12/devices/0000:00:18.4
/sys/kernel/iommu_groups/12/devices/0000:00:18.2
/sys/kernel/iommu_groups/12/devices/0000:00:18.0
/sys/kernel/iommu_groups/12/devices/0000:00:18.7
/sys/kernel/iommu_groups/12/devices/0000:00:18.5
/sys/kernel/iommu_groups/40/devices/0000:45:00.2
/sys/kernel/iommu_groups/30/devices/0000:40:08.0
/sys/kernel/iommu_groups/2/devices/0000:00:01.3
/sys/kernel/iommu_groups/10/devices/0000:00:08.1
/sys/kernel/iommu_groups/39/devices/0000:45:00.0
/sys/kernel/iommu_groups/29/devices/0000:40:07.1
/sys/kernel/iommu_groups/19/devices/0000:0b:00.3
/sys/kernel/iommu_groups/37/devices/0000:44:00.2
/sys/kernel/iommu_groups/9/devices/0000:00:08.0
/sys/kernel/iommu_groups/27/devices/0000:40:04.0
[email protected] ~ $ lspci
06:00.0 IDE interface: ASMedia Technology Inc. ASM1061 SATA IDE Controller (rev 02)
08:00.0 USB controller: ASMedia Technology Inc. Device 2142
09:00.0 USB controller: ASMedia Technology Inc. Device 2142
0a:00.0 Non-Volatile memory controller: Intel Corporation Device f1a8 (rev 03)
0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 145a
0b:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
0b:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 1455
0c:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
0c:00.3 Audio device: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller
41:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1470 (rev c1)
42:00.0 PCI bridge: Advanced Micro Devices, Inc. [AMD] Device 1471
43:00.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Vega 10 XT [Radeon RX Vega 64] (rev c1)
43:00.1 Audio device: Advanced Micro Devices, Inc. [AMD/ATI] Device aaf8
44:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 145a
44:00.2 Encryption controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor
44:00.3 USB controller: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller
45:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device 1455
45:00.2 SATA controller: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] (rev 51)
[email protected] ~ $ lspci -tvv
 |           +-03.1-[41-43]----00.0-[42-43]----00.0-[43]--+-00.0  Advanced Micro Devices, Inc. [AMD/ATI] Vega 10 XT [Radeon RX Vega 64]
 |           |                                            \-00.1  Advanced Micro Devices, Inc. [AMD/ATI] Device aaf8
 |           +-07.1-[44]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 145a
 |           \-08.1-[45]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 1455
             |                               +-01.0-[04]--
             |                               +-02.0-[05]--
             |                               +-03.0-[06]----00.0  ASMedia Technology Inc. ASM1061 SATA IDE Controller
             |                               +-04.0-[07]--
             |                               \-09.0-[08]----00.0  ASMedia Technology Inc. Device 2142
             +-01.3-[09]----00.0  ASMedia Technology Inc. Device 2142
             +-01.5-[0a]----00.0  Intel Corporation Device f1a8
             +-07.1-[0b]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 145a
             +-08.1-[0c]--+-00.0  Advanced Micro Devices, Inc. [AMD] Device 1455
I can add an additional GPU and PCI-E WiFi card to rig and rerun above and share if that helps?
*** edit ***
I have not done anything to Linux Mint, when run command:-
dmesg | grep -i -e DMAR -e IOMMU
I get in terminal:-
[email protected] ~ $ dmesg | grep -i -e DMAR -e IOMMU
[    0.800960] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[    0.801001] pci 0000:40:00.2: AMD-Vi: IOMMU performance counters supported
[    0.802029] pci 0000:00:01.0: Adding to iommu group 0
[    0.802536] pci 0000:00:01.1: Adding to iommu group 1
[    0.803107] pci 0000:00:01.3: Adding to iommu group 2
[    0.803634] pci 0000:00:01.5: Adding to iommu group 3
[    0.804238] pci 0000:00:02.0: Adding to iommu group 4
[    0.804824] pci 0000:00:03.0: Adding to iommu group 5
[    0.805359] pci 0000:00:04.0: Adding to iommu group 6
[    0.805951] pci 0000:00:07.0: Adding to iommu group 7
[    0.806443] pci 0000:00:07.1: Adding to iommu group 8
[    0.806985] pci 0000:00:08.0: Adding to iommu group 9
[    0.807476] pci 0000:00:08.1: Adding to iommu group 10
[    0.808051] pci 0000:00:14.0: Adding to iommu group 11
[    0.808066] pci 0000:00:14.3: Adding to iommu group 11
[    0.808607] pci 0000:00:18.0: Adding to iommu group 12
[    0.808624] pci 0000:00:18.1: Adding to iommu group 12
[    0.808638] pci 0000:00:18.2: Adding to iommu group 12
[    0.808652] pci 0000:00:18.3: Adding to iommu group 12
[    0.808666] pci 0000:00:18.4: Adding to iommu group 12
[    0.808680] pci 0000:00:18.5: Adding to iommu group 12
[    0.808694] pci 0000:00:18.6: Adding to iommu group 12
[    0.808708] pci 0000:00:18.7: Adding to iommu group 12
[    0.809358] pci 0000:00:19.0: Adding to iommu group 13
[    0.809373] pci 0000:00:19.1: Adding to iommu group 13
[    0.809388] pci 0000:00:19.2: Adding to iommu group 13
[    0.809403] pci 0000:00:19.3: Adding to iommu group 13
[    0.809417] pci 0000:00:19.4: Adding to iommu group 13
[    0.809432] pci 0000:00:19.5: Adding to iommu group 13
[    0.809446] pci 0000:00:19.6: Adding to iommu group 13
[    0.809463] pci 0000:00:19.7: Adding to iommu group 13
[    0.809959] pci 0000:01:00.0: Adding to iommu group 14
[    0.809981] pci 0000:01:00.1: Adding to iommu group 14
[    0.810002] pci 0000:01:00.2: Adding to iommu group 14
[    0.810012] pci 0000:02:00.0: Adding to iommu group 14
[    0.810022] pci 0000:02:01.0: Adding to iommu group 14
[    0.810031] pci 0000:02:02.0: Adding to iommu group 14
[    0.810041] pci 0000:02:03.0: Adding to iommu group 14
[    0.810051] pci 0000:02:04.0: Adding to iommu group 14
[    0.810061] pci 0000:02:09.0: Adding to iommu group 14
[    0.810075] pci 0000:03:00.0: Adding to iommu group 14
[    0.810086] pci 0000:06:00.0: Adding to iommu group 14
[    0.810101] pci 0000:08:00.0: Adding to iommu group 14
[    0.810630] pci 0000:09:00.0: Adding to iommu group 15
[    0.811078] pci 0000:0a:00.0: Adding to iommu group 16
[    0.811589] pci 0000:0b:00.0: Adding to iommu group 17
[    0.812060] pci 0000:0b:00.2: Adding to iommu group 18
[    0.812588] pci 0000:0b:00.3: Adding to iommu group 19
[    0.813015] pci 0000:0c:00.0: Adding to iommu group 20
[    0.813511] pci 0000:0c:00.2: Adding to iommu group 21
[    0.813995] pci 0000:0c:00.3: Adding to iommu group 22
[    0.814541] pci 0000:40:01.0: Adding to iommu group 23
[    0.815034] pci 0000:40:02.0: Adding to iommu group 24
[    0.815562] pci 0000:40:03.0: Adding to iommu group 25
[    0.816018] pci 0000:40:03.1: Adding to iommu group 26
[    0.816515] pci 0000:40:04.0: Adding to iommu group 27
[    0.817047] pci 0000:40:07.0: Adding to iommu group 28
[    0.817438] pci 0000:40:07.1: Adding to iommu group 29
[    0.817937] pci 0000:40:08.0: Adding to iommu group 30
[    0.818451] pci 0000:40:08.1: Adding to iommu group 31
[    0.818906] pci 0000:41:00.0: Adding to iommu group 32
[    0.819432] pci 0000:42:00.0: Adding to iommu group 33
[    0.819907] pci 0000:43:00.0: Adding to iommu group 34
[    0.820014] pci 0000:43:00.0: Using iommu direct mapping
[    0.820302] pci 0000:43:00.1: Adding to iommu group 35
[    0.820788] pci 0000:44:00.0: Adding to iommu group 36
[    0.821258] pci 0000:44:00.2: Adding to iommu group 37
[    0.821765] pci 0000:44:00.3: Adding to iommu group 38
[    0.822227] pci 0000:45:00.0: Adding to iommu group 39
[    0.822736] pci 0000:45:00.2: Adding to iommu group 40
[    0.822860] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.822863] pci 0000:40:00.2: AMD-Vi: Found IOMMU cap 0x40
[    0.824425] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[    0.824442] perf/amd_iommu: Detected AMD IOMMU #1 (2 banks, 4 counters/bank).
[    1.263974] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <[email protected]>
Ran also script:-
#!/bin/bash
shopt -s nullglob
for g in /sys/kernel/iommu_groups/*; do
    echo "IOMMU Group ${g##*/}:"
    for d in $g/devices/*; do
        echo -e "\t$(lspci -nns ${d##*/})"
    done;
done;
Result:-
IOMMU Group 0:
	00:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 1:
	00:01.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 10:
	00:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 11:
	00:14.0 SMBus [0c05]: Advanced Micro Devices, Inc. [AMD] FCH SMBus Controller [1022:790b] (rev 59)
	00:14.3 ISA bridge [0601]: Advanced Micro Devices, Inc. [AMD] FCH LPC Bridge [1022:790e] (rev 51)
IOMMU Group 12:
	00:18.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
	00:18.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
	00:18.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
	00:18.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
	00:18.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
	00:18.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
	00:18.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
	00:18.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
IOMMU Group 13:
	00:19.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 0 [1022:1460]
	00:19.1 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 1 [1022:1461]
	00:19.2 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 2 [1022:1462]
	00:19.3 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 3 [1022:1463]
	00:19.4 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 4 [1022:1464]
	00:19.5 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 5 [1022:1465]
	00:19.6 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 6 [1022:1466]
	00:19.7 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Data Fabric: Device 18h; Function 7 [1022:1467]
IOMMU Group 14:
	01:00.0 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset USB 3.1 xHCI Controller [1022:43ba] (rev 02)
	01:00.1 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset SATA Controller [1022:43b6] (rev 02)
	01:00.2 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] X399 Series Chipset PCIe Bridge [1022:43b1] (rev 02)
	02:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	02:01.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	02:02.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	02:03.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	02:04.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	02:09.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] 300 Series Chipset PCIe Port [1022:43b4] (rev 02)
	03:00.0 Network controller [0280]: Intel Corporation Wireless-AC 9260 [8086:2526] (rev 29)
	06:00.0 IDE interface [0101]: ASMedia Technology Inc. ASM1061 SATA IDE Controller [1b21:0611] (rev 02)
	08:00.0 USB controller [0c03]: ASMedia Technology Inc. Device [1b21:2142]
IOMMU Group 15:
	09:00.0 USB controller [0c03]: ASMedia Technology Inc. Device [1b21:2142]
IOMMU Group 16:
	0a:00.0 Non-Volatile memory controller [0108]: Intel Corporation Device [8086:f1a8] (rev 03)
IOMMU Group 17:
	0b:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:145a]
IOMMU Group 18:
	0b:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
IOMMU Group 19:
	0b:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller [1022:145c]
IOMMU Group 2:
	00:01.3 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 20:
	0c:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1455]
IOMMU Group 21:
	0c:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 22:
	0c:00.3 Audio device [0403]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) HD Audio Controller [1022:1457]
IOMMU Group 23:
	40:01.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 24:
	40:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 25:
	40:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 26:
	40:03.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 27:
	40:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 28:
	40:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 29:
	40:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 3:
	00:01.5 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe GPP Bridge [1022:1453]
IOMMU Group 30:
	40:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 31:
	40:08.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 32:
	41:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1470] (rev c1)
IOMMU Group 33:
	42:00.0 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Device [1022:1471]
IOMMU Group 34:
	43:00.0 VGA compatible controller [0300]: Advanced Micro Devices, Inc. [AMD/ATI] Vega 10 XT [Radeon RX Vega 64] [1002:687f] (rev c1)
IOMMU Group 35:
	43:00.1 Audio device [0403]: Advanced Micro Devices, Inc. [AMD/ATI] Device [1002:aaf8]
IOMMU Group 36:
	44:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:145a]
IOMMU Group 37:
	44:00.2 Encryption controller [1080]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Platform Security Processor [1022:1456]
IOMMU Group 38:
	44:00.3 USB controller [0c03]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) USB 3.0 Host Controller [1022:145c]
IOMMU Group 39:
	45:00.0 Non-Essential Instrumentation [1300]: Advanced Micro Devices, Inc. [AMD] Device [1022:1455]
IOMMU Group 4:
	00:02.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 40:
	45:00.2 SATA controller [0106]: Advanced Micro Devices, Inc. [AMD] FCH SATA Controller [AHCI mode] [1022:7901] (rev 51)
IOMMU Group 5:
	00:03.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 6:
	00:04.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 7:
	00:07.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
IOMMU Group 8:
	00:07.1 PCI bridge [0604]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) Internal PCIe GPP Bridge 0 to Bus B [1022:1454]
IOMMU Group 9:
	00:08.0 Host bridge [0600]: Advanced Micro Devices, Inc. [AMD] Family 17h (Models 00h-0fh) PCIe Dummy Host Bridge [1022:1452]
wow interesting ... my bios do not detect card in slot 1... is this cause it's 2080ti card or what?
does it mean cpu/motherboard is bad or what?
card works fine it gives output but does not show up in bios and in IOMMU groups.
I literally display this BIOS from my 2080ti and also it's there is linux/windows etc...
Is it asus or nvidia issue ? I belive they messed up completely bios, which does not talk correctly to nvidia card.
Meddling user
Discussion Starter · #18 · (Edited)
Dunno why your GPU is not seen in UEFI, may be an issue with ASUS or nVidia FW, dunno really.
I can not say if your HW has fault, when I transferred 1950X to ZEA I didn't even use torque tool, just hand tightened screws. Both ZE and ZEA had Foxconn sockets and both never an issue for screwing down, etc. I have read info on web condemning these sockets, my experience has differed.
From what I checked on my system it supports IOMMU and components are interacting as they should. If I have time this week will try some other stuff.
Your outputs in post 15 do contain GPUs.
2080 Ti
GT 710
Screen shot in post 17 has GT 710 in IOMMU group 20, can't see the RTX 2080 Ti.
exactly that's the issue it's not there in ubuntu 19 iommu (txt), it's not there in unraid (photo).
strange! I have no explanation for it.
[2019/06/09 10:35:21]
Ai Overclock Tuner [Manual]
BCLK Frequency [Auto]
Custom CPU Core Ratio [Manual]
> FID [160]
> DID [8]
Overclocking Enhancement [Disabled]
Performance Bias [Auto]
Memory Frequency [DDR4-3400MHz]
Core Performance Boost [Disabled]
SMT Mode [Auto]
Spread Spectrum [Auto]
EPU Power Saving Mode [Disabled]
TPU [Keep Current Settings]
TRC_EOM [Auto]
TRTP_EOM [Auto]
TRRS_S_EOM [Auto]
TRRS_L_EOM [Auto]
TWTR_EOM [Auto]
TWTR_L_EOM [Auto]
TWCL_EOM [Auto]
TWR_EOM [Auto]
TFAW_EOM [Auto]
TRCT_EOM [Auto]
TREFI_EOM [Auto]
TRDRD_DD_EOM [Auto]
TRDRD_SD_EOM [Auto]
TRDRD_SC_EOM [Auto]
TRDRD_SCDLR_EOM [Auto]
TRDRD_SCL_EOM [Auto]
TWRWR_DD_EOM [Auto]
TWRWR_SD_EOM [Auto]
TWRWR_SC_EOM [Auto]
TWRWR_SCDLR_EOM [Auto]
TWRWR_SCL_EOM [Auto]
TWRRD_EOM [Auto]
TRDWR_EOM [Auto]
TWRRD_SCDLR_EOM [Auto]
Mem Over Clock Fail Count [Auto]
DRAM CAS# Latency [14]
DRAM RAS# to CAS# Read Delay [15]
DRAM RAS# to CAS# Write Delay [14]
DRAM RAS# PRE Time [14]
DRAM RAS# ACT Time [30]
Trc [44]
TrrdS [6]
TrrdL [6]
Tfaw [34]
TwtrS [4]
TwtrL [12]
Twr [12]
Trcpage [Auto]
TrdrdScl [3]
TwrwrScl [3]
Trfc [326]
Trfc2 [Auto]
Trfc4 [Auto]
Tcwl [14]
Trtp [8]
Trdwr [7]
Twrrd [4]
TwrwrSc [1]
TwrwrSd [7]
TwrwrDd [7]
TrdrdSc [1]
TrdrdSd [5]
TrdrdDd [5]
Tcke [1]
ProcODT [53.3 ohm]
Cmd2T [1T]
Gear Down Mode [Enabled]
Power Down Enable [Enabled]
RttNom [60 Ohm]
RttWr [Dynamic ODT Off]
RttPark [48 Ohm]
MemAddrCmdSetup [Auto]
MemCsOdtSetup [Auto]
MemCkeSetup [Auto]
MemCadBusClkDrvStren [24.0 Ohm]
MemCadBusAddrCmdDrvStren [24.0 Ohm]
MemCadBusCsOdtDrvStren [24.0 Ohm]
MemCadBusCkeDrvStren [24.0 Ohm]
CPU Load-line Calibration [Level 5]
CPU Current Capability [Auto]
CPU VRM Switching Frequency [Auto]
VRM Spread Spectrum [Auto]
CPU Power Duty Control [T.Probe]
CPU Power Phase Control [Auto]
CPU Power Thermal Control [120]
VDDSOC Load-line Calibration [Auto]
VDDSOC Current Capability [Auto]
VDDSOC Switching Frequency [Auto]
VDDSOC Phase Control [Auto]
VDDSOC Power Thermal Control [120]
DRAM Current Capability(CHA, CHB) [100%]
DRAM Current Capability(CHC, CHD) [100%]
DRAM Power Phase Control(CHA, CHB) [Extreme]
DRAM Power Phase Control(CHC, CHD) [Extreme]
DRAM Switching Frequency(CHA, CHB) [Auto]
DRAM Switching Frequency(CHC, CHD) [Auto]
DRAM VBoot Voltage AB [Auto]
DRAM VBoot Voltage CD [Auto]
VTTDDR AB Voltage [Auto]
VTTDDR CD Voltage [Auto]
DRAM CTRL REF Voltage on CHA [Auto]
DRAM CTRL REF Voltage on CHB [Auto]
DRAM CTRL REF Voltage on CHC [Auto]
DRAM CTRL REF Voltage on CHD [Auto]
VPP DRAM AB [Auto]
VPP DRAM CD [Auto]
1.8V Standby Voltage [Auto]
CPU 3.3v AUX [Auto]
2.5V SB Voltage [Auto]
DRAM R1 Tune [Auto]
DRAM R2 Tune [Auto]
DRAM R3 Tune [Auto]
DRAM R4 Tune [Auto]
Sense MI Skew [Disabled]
Sense MI Offset [Auto]
Clock Amplitude [Auto]
PLL Tune R1 [Auto]
PLL Tune R2 [Auto]
PCIE Tune R1 [Auto]
PCIE Tune R2 [Auto]
PCIE Tune R3 [Auto]
Ln2 Tune [Auto]
PLL Reference Voltage [Auto]
PLL Reference Voltage 2 [Auto]
Short Reset [Auto]
CLDO VDDP voltage [Auto]
CPU Core Voltage [Manual mode]
- CPU Core Voltage Override [1.31250]
CPU SOC Voltage [Manual mode]
- VDDSOC Voltage Override [1.02500]
DRAM AB Voltage [1.40000]
DRAM CD Voltage [1.40000]
1.8V PLL Voltage [Auto]
1.05V SB Voltage [Auto]
TPM Device Selection [Discrete TPM]
Erase fTPM NV for factory reset [Enabled]
SATA Port Enable [Enabled]
SATA Mode [AHCI]
SMART Self Test [Enabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
Hot Plug [Disabled]
HD Audio Controller [Enabled]
CPU PCIE Link Mode [GEN 3]
SB PCIE Link Mode [GEN 3]
PCIEX16_1 Bandwidth [X16 Mode]
PCIEX16_2 Bandwidth [X8 Mode]
PCIEX16_3 Bandwidth [X16 Mode]
PCIEX16_4 Bandwidth [X4 Mode]
Asmedia USB 3.1 Controller [Enabled]
ASMedia Storage Controller [Enabled]
ASPM Support [Disabled]
When system is in working state [All On]
10G LAN Card [Enabled]
10G LAN PXE Option ROM [Disabled]
Intel LAN Controller [Enabled]
Intel LAN OPROM [Disabled]
Wi-Fi Controller [Enabled]
Bluetooth Controller [Enabled]
USB power delivery in Soft Off state (S5) [Disabled]
ErP Ready [Enable(S4+S5)]
Restore On AC Power Loss [Power Off]
Power On By PCI-E/PCI [Disabled]
Power On By RTC [Disabled]
NX Mode [Enabled]
SVM Mode [Enabled]
Above 4G Decoding [Enabled]
SR-IOV Support [Enabled]
Network Stack [Disabled]
Device [Samsung SSD 850 EVO 500GB]
Legacy USB Support [Enabled]
XHCI Hand-off [Enabled]
KingstonDataTraveler 3.0PMAP [Auto]
U31G2_EC1 [Enabled]
U31G2_E2 [Enabled]
U31G2_E3 [Enabled]
U31G2_E4 [Enabled]
U31G2_1 [Enabled]
U31G1_1 [Enabled]
U31G1_2 [Enabled]
U31G1_3 [Enabled]
U31G1_4 [Enabled]
U31G1_5 [Enabled]
U31G1_6 [Enabled]
U31G1_7 [Enabled]
U31G1_8 [Enabled]
U31G1_9 [Enabled]
U31G1_10 [Enabled]
U31G1_11 [Enabled]
U31G1_12 [Enabled]
USB13 [Enabled]
USB14 [Enabled]
USB15 [Enabled]
USB16 [Enabled]
CPU Temperature [Monitor]
MotherBoard Temperature [Monitor]
VRM Temperature [Monitor]
PCH Temperature [Monitor]
PSU Temperature [Monitor]
T_Sensor1 Temperature [Monitor]
T_Sensor2 Temperature [Monitor]
DIMM.2 sensor1 Temperature [Monitor]
DIMM.2 sensor2 Temperature [Monitor]
EXT_Sensor1  Temperature [Monitor]
EXT_Sensor2  Temperature [Monitor]
EXT_Sensor3  Temperature [Monitor]
CPU Fan Speed [Monitor]
Chassis Fan 1 Speed [Monitor]
Chassis Fan 2 Speed [Monitor]
HAMP Fan Speed [Monitor]
W_PUMP+ Speed [Monitor]
CPU Optional Fan Speed [Monitor]
Extension Fan 1 Speed [Monitor]
Extension Fan 2 Speed [Monitor]
Extension Fan 3 Speed [Monitor]
Extension Fan 4 Speed [Monitor]
Extension Fan 5 Speed [Monitor]
Extension Fan 6 Speed [Monitor]
HS Fan Speed [Monitor]
FLOW_RATE [Monitor]
Water In T Sensor Temperature [Monitor]
Water Out T Sensor Temperature [Monitor]
WB_FLOW_RATE [Monitor]
WB In T Sensor Temperature [Monitor]
WB Out T Sensor Temperature [Monitor]
PSU Fan Speed [Monitor]
PSU Power [Monitor]
PSU Vin Voltage [Monitor]
CPU Core Voltage [Monitor]
3.3V Voltage [Monitor]
5V Voltage [Monitor]
12V Voltage [Monitor]
CPU Q-Fan Control [PWM Mode]
CPU Fan Smoothing Up/Down Time [0 sec]
CPU Fan Speed Lower Limit [600 RPM]
CPU Fan Profile [Manual]
CPU Upper Temperature [50]
CPU Fan Max. Duty Cycle (%) [100]
CPU Middle Temperature [45]
CPU Fan Middle. Duty Cycle (%) [100]
CPU Lower Temperature [10]
CPU Fan Min. Duty Cycle (%) [100]
Chassis Fan 1 Q-Fan Control [Auto]
Chassis Fan 1 Q-Fan Source [CPU]
Chassis Fan 1 Smoothing Up/Down Time [0 sec]
Chassis Fan 1 Speed Low Limit [200 RPM]
Chassis Fan 1 Profile [Standard]
Chassis Fan 2 Q-Fan Control [Auto]
Chassis Fan 2 Q-Fan Source [CPU]
Chassis Fan 2 Smoothing Up/Down Time [0 sec]
Chassis Fan 2 Speed Low Limit [200 RPM]
Chassis Fan 2 Profile [Standard]
HAMP Fan Q-Fan Control [Auto]
HAMP Fan Source [CPU]
HAMP Fan Smoothing Up/Down Time [0 sec]
HAMP Fan Speed Low Limit [200 RPM]
HAMP Fan Profile [Standard]
Extension Fan 1 Q-Fan Control [Auto]
Extension Fan 1 Q-Fan Source [CPU]
Extension Fan 1 Speed Low Limit [200 RPM]
Extension Fan 1 Profile [Standard]
Extension Fan 2 Q-Fan Control [Auto]
Extension Fan 2 Q-Fan Source [CPU]
Extension Fan 2 Speed Low Limit [200 RPM]
Extension Fan 2 Profile [Standard]
Extension Fan 3 Q-Fan Control [Auto]
Extension Fan 3 Q-Fan Source [Multiple Sources]
Temperature Source 1 [EXT_Sensor1]
Temperature Source 2 [EXT_Sensor3]
Temperature Source 3 [N/A]
Extension Fan 3 Speed Low Limit [600 RPM]
Extension Fan 3 Profile [Manual]
Extension Fan 3 Upper Temperature [40]
Extension Fan 3 Max. Duty Cycle (%) [100]
Extension Fan 3 Middle Temperature [34]
Extension Fan 3 Middle. Duty Cycle (%) [65]
Extension Fan 3 Lower Temperature [34]
Extension Fan 3 Min. Duty Cycle (%) [65]
Extension Fan 4 Q-Fan Control [Auto]
Extension Fan 4 Q-Fan Source [CPU]
Extension Fan 4 Speed Low Limit [200 RPM]
Extension Fan 4 Profile [Standard]
Extension Fan 5 Q-Fan Control [Auto]
Extension Fan 5 Q-Fan Source [Multiple Sources]
Extension Fan 5 Speed Low Limit [600 RPM]
Extension Fan 5 Profile [Manual]
Extension Fan 5 Upper Temperature [36]
Extension Fan 5 Max. Duty Cycle (%) [100]
Extension Fan 5 Middle Temperature [32]
Extension Fan 5 Middle. Duty Cycle (%) [70]
Extension Fan 5 Lower Temperature [32]
Extension Fan 5 Min. Duty Cycle (%) [70]
Extension Fan 6 Q-Fan Control [Auto]
Extension Fan 6 Q-Fan Source [Multiple Sources]
Extension Fan 6 Speed Low Limit [600 RPM]
Extension Fan 6 Profile [Manual]
Extension Fan 6 Upper Temperature [36]
Extension Fan 6 Max. Duty Cycle (%) [100]
Extension Fan 6 Middle Temperature [32]
Extension Fan 6 Middle. Duty Cycle (%) [70]
Extension Fan 6 Lower Temperature [32]
Extension Fan 6 Min. Duty Cycle (%) [70]
W_PUMP+ Control [Disabled]
Heatsink Fan Q-Fan Control [PWM Mode]
Heatsink Fan Smoothing Up/Down Time [0 sec]
Heatsink Fan Speed Low Limit [Ignore]
Heatsink Fan Profile [Manual]
Heatsink Fan Upper Temperature [75]
Heatsink Fan Max. Duty Cycle (%) [60]
Heatsink Fan Middle Temperature [80]
Heatsink Fan Middle. Duty Cycle (%) [30]
Heatsink Fan Lower Temperature [60]
Heatsink Fan Min. Duty Cycle (%) [0]
Power Supply Unit  Fan Q-Fan Control [PWM Mode]
Power Supply Unit Fan Speed Low Limit [200 RPM]
Power Supply Unit  Fan Profile [Standard]
Fast Boot [Enabled]
Next Boot after AC Power Loss [Normal Boot]
Boot Logo Display [Auto]
POST Delay Time [3 sec]
Boot up NumLock State [Enabled]
Wait For 'F1' If Error [Enabled]
Option ROM Messages [Enabled]
Interrupt 19 Capture [Disabled]
Setup Mode [Advanced Mode]
Launch CSM [Enabled]
Boot Device Control [UEFI and Legacy OPROM]
Boot from Network Devices [Legacy only]
Boot from Storage Devices [Legacy only]
Boot from PCI-E Expansion Devices [Legacy only]
OS Type [Other OS]
Setup Animator [Disabled]
Profile Name [3466]
Save to Profile [1]
DIMM Slot Number [DIMM_A1]
Download & Install ARMOURY CRATE app [Enabled]
Bus Interface [PCIEX16_3]
RedirectForReturnDis [Auto]
L2 TLB Associativity [Auto]
Platform First Error Handling [Disabled]
Enable IBS [Auto]
Global C-state Control [Auto]
Power Supply Idle Control [Auto]
Opcache Control [Auto]
OC Mode [Normal Operation]
Relaxed EDC throttling [Auto]
SEV-ES ASID Space Limit [1]
Streaming Stores Control [Auto]
ACPI _CST C1 Declaration [Auto]
L1 Stream HW Prefetcher [Auto]
L2 Stream HW Prefetcher [Auto]
SMU and PSP Production Mode [Auto]
DRAM scrub time [Auto]
Redirect scrubber control [Auto]
Disable DF sync flood propagation [Auto]
Freeze DF module queues on error [Auto]
GMI encryption control [Auto]
xGMI encryption control [Auto]
CC6 memory region encryption [Auto]
Location of private memory regions [Auto]
System probe filter [Auto]
Memory interleaving [Channel]
Memory interleaving size [2 KB]
Channel interleaving hash [Enabled]
Memory Clear [Disabled]
ACPI SLIT Distance Control [Auto]
Overclock [Enabled]
Memory Clock Speed [Auto]
Tcl [Auto]
Trcdrd [Auto]
Trcdwr [Auto]
Trp [Auto]
Tras [Auto]
Trc Ctrl [Auto]
TrrdS [Auto]
TrrdL [Auto]
Tfaw Ctrl [Auto]
TwtrS [Auto]
TwtrL [Auto]
Twr Ctrl [Auto]
Trcpage Ctrl [Auto]
TrdrdScL Ctrl [Auto]
TwrwrScL Ctrl [Auto]
Trfc Ctrl [Auto]
Trfc2 Ctrl [Auto]
Trfc4 Ctrl [Auto]
Fail_CNT [5]
ProcODT [Auto]
Tcwl [Auto]
Trtp [Auto]
Trdwr [Auto]
Twrrd [Auto]
TwrwrSc [Auto]
TwrwrSd [Auto]
TwrwrDd [Auto]
TrdrdSc [Auto]
TrdrdSd [Auto]
TrdrdDd [Auto]
Tcke [Auto]
Power Down Enable [Auto]
Cmd2T [Auto]
Gear Down Mode [Auto]
CAD Bus Timing User Controls [Auto]
CAD Bus Drive Strength User Controls [Auto]
Data Bus Configuration User Controls [Auto]
DFE Read Training [Enable]
FFE Write Training [Auto]
PMU Pattern Bits Control [Auto]
Data Poisoning [Auto]
DRAM ECC Symbol Size [Auto]
DRAM ECC Enable [Auto]
TSME [Auto]
Data Scramble [Auto]
Chipselect Interleaving [Auto]
BankGroupSwap [Auto]
BankGroupSwapAlt [Auto]
Address Hash Bank [Auto]
Address Hash CS [Auto]
MBIST Enable [Disabled]
IOMMU [Auto]
Determinism Slider [Auto]
cTDP Control [Auto]
Fan Control [Auto]
PSI [Auto]
ACS Enable [Auto]
Enable AER Cap [Auto]
PCIe ARI Support [Auto]
CLDO_VDDP Control [Auto]
HD Audio Enable [Auto]
SOC OVERCLOCK VID [0]
Block PCIe Loopback [Auto]
CRS Delay [6]
CRS Limit [6]
Ignore sideband [Disabled]
Disable L1 w/a [Disabled]
Disable BridgeDis [Disabled]
Toggle RRC Enable [Disabled]
IRQ sets BridgeDis [Disabled]
PCIE RESET Control [Disabled]
AMD XGBE Controller 0 [Auto]
AMD XGBE Controller 1 [Auto]
AMD XGBE Controller 2 [Auto]
AMD XGBE Controller 3 [Auto]
AMD XGBE Controller 4 [Auto]
AMD XGBE Controller 5 [Auto]
AMD XGBE Controller 6 [Auto]
AMD XGBE Controller 7 [Auto]
NTB Enable [Auto]
Meddling user
Discussion Starter · #20 · (Edited)
Yesterday I did fresh install of Windows 10 Pro using 1903 iso and Linux Mint v19.1 (Tessa Cinnamon Edition). All updates installed to each, IIRC v5.1.8 kernel on LM. IOMMU grouping as posted before, when using Linux Mint v18.3 (Sylvia Cinnamon Edition, v5.1.8 kernel).
I can't see anything in txt that stands out to cause POST, other than perhaps it is CPU & RAM OC profile issue.
Reading your past posts to piece together specs:-
CPU: 1950X
RAM: F4-3600C16Q-GTZR
NVMe: SN720
GPU: RTX 2080 Ti, GT 710
3400MHz C14 I can encounter post issues if not enough SOC/VDIMM, so inclined to believe the issue of stuck/multiple POST is OC profile related.
1 - 20 of 119 Posts
