1 - 3 of 3 Posts
I've been having problems with trying to sli my 670s. I can't load any games because they crash as soon as they start. I keep getting a locale ID 1033. This happened when I tried to sli my 480s before. Single cards work in top slot and bottom slot but as soon as I sli I get problems. Do I have to get another mobo?
heres problem
Problem signature:
Problem Event Name: APPCRASH
Application Name: Crysis3.exe
Application Version: 1.0.0.1
Application Timestamp: 02f4d040
Fault Module Name: Crysis3.exe
Fault Module Version: 1.0.0.1
Fault Module Timestamp: 02f4d040
Exception Code: c0000005
Exception Offset: 01d61af2
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 528d
Additional Information 2: 528d466643aecbc7e055b4b2625bdce3
Additional Information 3: 7779
Additional Information 4: 7779dd32d9badb7fc2a796113b089758
First of all, add a sig rig here: http://www.overclock.net/rigbuilder
Then it will be much easier to see where the problem is right away!
For now, is your system completely stable? Good enough PSU?
Sometimes the SLI bridge could be the problem, try to push it tightly and perhaps try to turn it around.
If you have another SLI bridge, you can try with that one and see if it fixes the issue.
I have also experienced that a clean install of windows is needed to get SLI working properly!
Good luck
EDIT: Saw you edit yours with crysis info, on the latest driver? Same in all games?
1 - 3 of 3 Posts
