I think my x570 TUF is dying. After being the most stable system I've ever had... The past month+ it's exhibited weird behavior that has become progressively worse. To the point now the system is crashing every 30 minutes to 2 hours. Nothing shows in event viewer and no BSOD'S or anything to show the error.
System just goes blank and reboots when IDLE or doing light work like streaming Netflix. Usually my nvme disappears from the bios. Sometimes during the reboot after the crash it hangs on POST or Windows log in screen. I thought the nvme was dying but I took it out and booted off a different W10 install on an ssd. Same thing happened after 4 hours of use.
Tried cmos resets and all stock everything, didn't help. Tried both m.2 slots. Only two things left to try is a BIOS update but I've been on same BIOS for year+ no issues... Why now? And try unplugging ALL sata drives to try nvme by itself. Maybe one of the ssd is causing it?
It's like the motherboard is losing the ability to handle sata drives. Like they just disappear while using the pc. I don't know. I'm at a loss.
Edit: Got home from work booted to secondary win10 install on one of my SSD's. Took a dump within 3 minutes. Boot up again, dump within 3 minutes. Removed ALL Sata drives and ran off ONLY nvme. Worked for ~3 hours then took a dump. Updated BIOS to latest 4403 and still running ONLY nvme... Waiting to see if it takes a dump again. There's about 4 months left on the warranty but I hear Asus is a total nightmare to deal with.
Edit 2: It took a dump on new BIOS too :/
