Hey OCN,
I'm racking my brains on which laptop to get. I've narrowed it down to these very similar-but-different models. here's the rundown on the differences:
UL30VT<------------------------------------->UL80VT
LCD
13.3" 1366x768 LCD<--------------------->14" 1366x768
Dimensions/Weight
32.2W x 23.3D x 1.48~2.46H cm<------> 33.8W x 24.0D x 1.40~2.68H cm
3.74LB<-------------------------------------->4.8LB
Storage
500GB<-------------------------------------->320GB
Optical Drive
No Optical Drive<--------------------------->DVD burner
Key Size
30.2mm<------------------------------------>34.8mm
Price
$799.99<------------------------------------>$819.95
Other than these things, i think they are identical.
Ive never owned a laptop so i don't know how the shrunken keys will affect typing. Also, i know that the res is the same so i will have the same screen real-estate but will it reduce my eyestrain on 14"? and to the mobile crowd, is 4.8lb heavy to carry around a lot?
PS: the price difference means nothing to me and i eventually plan on throwing in an SSD
Which do you guys think would make the better laptop?
Thanks
LCD
Dimensions/Weight
Storage
Optical Drive
Key Size
Price
Thanks
