1 - 4 of 4 Posts
Old C-130 Guy
How well does this feature work?
My Sabertooth 990FX R2.0 came in yesterday but I have OEM windows Vista and it wouldn't boot in (didn't think it would, but had to try). So now I'm waiting on my Windows 7 Pro to come in from Newegg. While I was in UEFI I noticed it was version 1503 and 1903 is the new one so I'm thinking about just pluging main power to it and giving this feature a try.
Please post your thoughts on doing this.
Thank You
Overclock Failed...
The Asus USB bios flashing has worked just fine for me.
And, no, you don't need an OS installed.
Why do you thong Win 7 will work when Vista wouldn't?
Old C-130 Guy
I just pulled my old Processor, MB and Ram out and dropped the new parts in and without re-installing Vista I tried to boot in and it wouldn't.
I have a OEM version of Vista (that I didn't even think about when I ordered the hardware)and more than likely It wouldn't let me activate it on the new hardware. So I pulled it all back out and dropped my old stuff back in until my Windows 7 gets here from Newegg..
I was thinking of just placing the MB on top of its own box and hooking up main power and flashing it that way before I install it if that would work...
Overclock Failed...
Well, the drivers are wrong for the new MB and CPU, and the BIOS settings(speed/timings/volts) are probably wrong for your new memory.
As for easy flash, I think you have to have an up and running PC as you have to install the wizard.
1 - 4 of 4 Posts
