@elmorI'm trying to find Founder's edition or other cards to test with. If someone is able to test with only bare minimums attached that would help rule things out (CPU, 1x memory stick, 2x 2080/Ti). Also remove USB devices, use CMOS default settings etc.
@elmor: You tested with a 1950X? Could the 2950X cause the problem?I'm trying to find Founder's edition or other cards to test with. If someone is able to test with only bare minimums attached that would help rule things out (CPU, 1x memory stick, 2x 2080/Ti). Also remove USB devices, use CMOS default settings etc.
I have the same problem with the 1950X.@elmor: You tested with a 1950X? Could the 2950X cause the problem?
Elmor, I have removed everything down to the CPU, Gpu’s and RAM. It didn’t work in that config, so I left everything unplugged and took out all but 1 RAM stick, it then worked flawlessly. It worked even with everything plugged back on. I need my RAM so I went back to full config with 1 GPU enabled for now. I did get to test it with two cards and it ran great. I am wondering if this has anything to do with the FEs BIOS that I’ve read is encrypted different if I read that right. I am going to check that both cards have the same BIOS tonight and see what I can find out.I'm trying to find Founder's edition or other cards to test with. If someone is able to test with only bare minimums attached that would help rule things out (CPU, 1x memory stick, 2x 2080/Ti). Also remove USB devices, use CMOS default settings etc.
Here are my working settings.
I also have .CMO file but overclock.net won't let me upload it. This is using BIOS version 1003. If you want a copy DM me your email address.
Yes. This is a problem with 2950x. Must use 1402. I tried.Thanks Skingun! Unfortunately, using 2950x and i guess that processor isn't supported in BIOS 1003. Only other fix for time being to get it to work is to remove all RAM except for the one in B1 slot (which effectively reduices me down to 8gb, lol). Still fingers crossed for a updated BIOS by EOW.
Fantastic!ZE 1501 https://www.mediafire.com/file/n9mikbzdi8h9bbv/ROG-ZENITH-EXTREME-ASUS-1501.zip/file
- Should solve 2x RTX 2080 getting stuck at 0E
This was just released internally, someone else seems to have fixed it for us /forum/images/smilies/smile.gif
