Useful guides/tips
Tools to flash and recover BIOS on ASUS P8xxx boards (FD44Editor, FTK)
Asus BIOSes with updated RAID ROM
[How-to] Flashing NEC/RENESAS USB 3.0 uPD720200/uPD720200A firmware
[How-to] Downgrade ASUS UEFI BIOS
[How-to] Update Intel ME Firmware
[How-to] Update Intel RAID Option ROM
[Guide] Maximus IV GENE-Z BIOS and Overclocking
[Guide] Maximus IV Extreme BIOS, Sandybridge CPU Overview, and CPU Overclocking
What's Changed?
P8Z68-M Pro
P8Z68-V
P8Z68-V/Gen3
P8Z68-V LX
P8Z68-V LE
P8Z68-V Pro
P8Z68-V Pro/Gen3
P8Z68 Deluxe
P8Z68 Deluxe/Gen3
Maximus IV Gene-Z
Maximus IV Gene-Z/Gen3
Maximus IV Extreme-Z
What's Changed?
4/22:
- Realtek High Definition Audio Driver: R2.71 (6.01.6886)
P8Z68-M Pro
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3905
- Enhance compatibility with some USB devices.
- Fixed Nvidia GTX 680 hang when running with UEFI driver.
Version 3902
- Improve system stability.
Version 3806
- Improve memory compatibility.
- Support new CPUs.
Version 3702
- Support new CPUs.
Version 0604
Version 0603
- Enhance compatibility with some keyboards.
Version 0601
- Enhance compatibility with some USB keyboards.
Version 0502
- Support new CPUs.
Version 0402
- First release.
Chipset
Video
- Intel INF Driver: 9.4.0.1017
- Intel Management Engine Driver: 9.0.2.1345
- Intel Management Engine Firmware: 8.1.30.1350
Audio
- LucidLogix Virtu Software: 1.2.114.21767
- Intel Graphics Media Accelerator Driver
Windows 7/8: 9.17.10.3071 (32-bit) / (64-bit) HD Graphics 4000/2500 only
Windows 7/8: 9.17.10.3062 (32-bit) / (64-bit) HD Graphics 3000/2000 only
Lan
USB 3.0
- Realtek Gigabit Ethernet Driver
- Windows 7 - 7.069.0304.2013
- Windows 8 - 8.012.0304.2013
SATA
- ASMedia USB 3.0 Driver: 1.16.4.0
- ASMedia USB 3.0 Firmware: 120816_02_02_6D
Utilities
- ASMedia SATA Controller Driver: 1.3.8.000
- Intel Rapid Storage Technology Driver: 12.5.0.1066
- AI Suite II
- AI Charger+ 1.00.10
- Asus Update 1.03.04
- EPU-6 1.03.15
- FAN Xpert 1.01.06
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.76
- MyLogo 1.02.04
- Probe II 1.00.47
- System Information 1.02.07
- TurboV EVO 1.01.21
- USB 3.0 Boost 1.02.06
P8Z68-V
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3402
- Improve Improve system stability.
- Support new CPUs.
Version 3304
- Updated Intel RST ROM.
Version 3203
- Support new CPUs.
Version 0902
- Enable support for Next Gen 22nm Processor.
Version 0706
- Fix FW54P PCI card compatibility issue.
- Fix the bug that the OEM activation version OS of window7 will hang at the "blue screen" if some graphics cards be installed in system.
- Fix USB Keyboard 3R-FKB3010UBK can't work issue.
- Fix Microsoft V1 receiver can't work issue.
- Fix S3 can't resume if CPU PLL over voltage is enabled.
- Fix the CPU and Chassis Fan speed will over the duty cycle setting range.
- Fix CPU ratio always keep at lowest after S4 resume and AC power lost.
- Improve DRAM compatibility.
- Support new CPUs.
Version 0606
- Update Intel Raid Option ROM.
- Improve System stability.
- Improve compatiblity with some Raid card model.
- Increase IGD share memory size to 512MB.
Version 0501
- Enable the support of Intel Rapid Storage Technology version 10.5.0.1026 release.
Note: For proper operation, please ensure to update Intel Rapid Storage Technology driver to version 10.5.0.1026 and BIOS to version 0501 before enabling Intel Smart Response Technology.
Update procedure for users needing Intel Smart Response Technology:
- Enter OS, and ensure Intel Smart Response Technology has been turned off under Intel Rapid Storage Technology interface.
- Install version Intel Rapid Storage Technology driver to version 10.5.0.1026.
- Reboot the system, and update BIOS to version 0501, then reboot.
- Enter the BIOS setup screen, press F5 to load BIOS default, then change the Intel SATA Port to RAID mode.
- Boot into OS, and re-enable Intel Smart Response Technology under Intel Rapid Storage Technology.
Chipset
Video
Audio
Lan
Bluetooth
- Intel Gigabit Ethernet Driver: 18.2
USB 3.0
- Atheros AR3011 Bluetooth Driver/Suite
- Windows 7/8 - 7.4.0.160
SATA
Utilities
- JMicron JMB36X Controller Driver: 1.17.65.11
- AI Suite II
- AI Charger+ 1.00.06
- Mobilink 1.00.40
- Asus Update 1.01.02
- BT Go! 1.00.34
- DIGI+ VRM 1.00.28
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- Matrix 1.02.42
- MyLogo 1.01.16
- Probe II 1.00.29
- System Information 1.00.18
- TurboV EVO 1.00.80
P8Z68-V/Gen3
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3402
- Support new CPUs.
Version 3304
Version 3201
- Support new CPUs.
Version 3101
- Support new CPUs.
Version 0301
- First release.
Chipset
Video
Audio
Lan
Bluetooth
USB 3.0
SATA
Utilities
- AI Suite II
- Mobilink 1.00.40
- BT Go! 1.00.34
- DIGI+ VRM 1.00.28
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- Matrix 1.02.42
- MyLogo 1.01.16
- Probe II 1.00.29
P8Z68-V LX
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 4003
Version 4001
Version 3904
- Support new CPUs.
Version 3703
- Support new CPUs.
Version 0703
Version 0602
- Support new CPUs.
Version 0401
- First release.
Chipset
Video
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DrvResource
- EPU-6 1.03.15
- FAN Xpert 1.01.06
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.76
- MyLogo 1.02.04
- Probe II 1.00.47
P8Z68-V LE
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3903
Version 3901
Version 3808
- Support new CPUs.
Version 3702
- Support new CPUs.
Version 0805
Version 0803
Version 0702
- Support new CPUs.
Version 0401
- First release.
Chipset
Video
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DrvResource
- EPU-6 1.03.15
- FAN Xpert 1.01.06
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.76
- MyLogo 1.02.04
- Probe II 1.00.47
P8Z68-V Pro
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3402
- Support new CPUs.
Version 3304
Version 3203
- Support new CPUs.
Version 1101
- Support new CPUs.
Version 0902
Version 0706
- Support new CPUs.
Version 0606
Version 0501
Version 0401
- Initial release.
Chipset
Video
Audio
Lan
Bluetooth
USB 3.0
SATA
Utilities
- Marvell SATA Controller Driver: 1.2.0.1032
- AI Suite II
- Mobilink 1.00.40
- BT Go! 1.00.34
- DIGI+ VRM 1.00.28
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- Matrix 1.02.42
- MyLogo 1.01.16
- Probe II 1.00.29
P8Z68-V Pro/Gen3
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3402
- Support new CPUs.
Version 3304
Version 3202
- Support new CPUs.
Version 0402
- Support new CPUs.
Version 0301
- Initial release.
Chipset
Video
Audio
Lan
Bluetooth
USB 3.0
SATA
Utilities
- AI Suite II
- Mobilink 1.00.40
- BT Go! 1.00.34
- DIGI+ VRM 1.00.28
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- Matrix 1.02.42
- MyLogo 1.01.16
- Probe II 1.00.29
P8Z68 Deluxe
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3304
Version 3203
- Support new CPUs.
Version 0902
Version 0706
- Improve compatibilty issue with some USB keyboards.
- Support new CPUs.
Version 0603
Version 0501
Chipset
Video
Audio
Lan
Bluetooth
USB 3.0
SATA
- NEC USB 3.0 Driver: 2.1.39.0
Utilities
- AI Suite II
- Mobilink 1.00.49
- Asus Update 1.02.05
- BT Go! 1.00.36
- DIGI+ VRM 1.00.28
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- ImageResource
- Matrix 1.02.42.01
- MyLogo 1.01.20
- Probe II 1.00.29
- System Information 1.00.26
P8Z68 Deluxe/Gen3
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3304
Version 3202
- Support new CPUs.
Version 0301
- First release.
Chipset
Video
Audio
Lan
Bluetooth
USB 3.0
SATA
Utilities
- AI Suite II
- Mobilink 1.00.49
- BT Go! 1.00.36
- DIGI+ VRM 1.00.28
- DrvResource
- EPU-6 1.02.10
- FAN Xpert 1.00.47
- ImageResource
- Matrix 1.02.42.01
- MyLogo 1.01.20
- Probe II 1.00.29
Maximus IV Gene-Z
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3402
- Support new CPUs.
Version 3305
Version 3203
- Support new CPUs.
Internal Beta Version 3202
Internal Beta Version 1001
Version 0902
Internal Beta Version 0603
- "Xtreme Tweaking" option for 3D01 in BIOS.
Internal Beta Version 0498
- Fixed some bugs.
Internal Beta Version 0496
- Tweaked for 3DMark2001.
Version 0403
Version 0208
- First release.
Chipset
Video
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- Asus Update 1.02.03
- DIGI+ VRM 1.01.10
- DrvResource
- EPU-6 1.02.12
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.42.01
- MyLogo 1.01.18
- Probe II 1.00.30
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3501
Version 3305
Version 3203
- Support new CPUs.
Version 0402
- First release.
Chipset
Video
Audio
Lan
USB 3.0
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.01.10
- DrvResource
- EPU-6 1.02.12
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.42.01
- MyLogo 1.01.18
- Probe II 1.00.30
PRODUCT LINK
Manual / Memory QVL
BIOS
Version 3603
None
Version 3510
- Support new CPUs.
Version 3501
Version 3402
- Support new CPUs.
Version 3304
Version 3203
- Support new CPUs.
Version 1004
Version 0902
Internal Beta Version 0604
- Fixed some bugs.
Version 0403
Internal Beta Version 0402
Version 0210
- First release.
Chipset
Audio
Lan
Bluetooth
USB 3.0
- Toshiba Bluetooth Stack Driver: 9.10.00
SATA
Utilities
- AI Suite II
- DIGI+ VRM 1.01.10
- DrvResource
- EPU-6 1.02.12
- FAN Xpert 1.00.47
- GPU Boost 1.01.05
- ImageResource
- Matrix 1.02.42.01
- MyLogo 1.01.18
- Probe II 1.00.30
