1 - 4 of 4 Posts
Don't flash a BIOS unless you are experiencing an issue and the new BIOS can solve it. NEVER interrupt a BIOS flash, will corrupt the BIOS and leave you dead in the water unless the mobo has two BIOS chips. Pick a time when it is very unlikely you'll loose electrical power, better yet, running with a battery backup UPS.
Use the EZ Flash Utility and a thumb drive FAT formatted.
forgive me for the nooby coment but what is FAT formatted??
BIOS updates, .rom or .cap, require the thumb drive to be formatted using the File Allocation Table (FAT) format. Its a way to format a device to get it ready to store data. The format you are probably familar with is NTFS (New Technology File System) used on most HDDs.
1 - 4 of 4 Posts
