Anyone know of a way to overclock an ASUS Z80k? My machine seems to have a lot of heat headroom to play with so I would like to try... Any ideas would be very helpfull.
Please help us help you by filling out your system specs. Click on user cp in the top bar and then on the left side click edit system specs. Fill in as much as you can.
Since it is a laptop you most likely won't be able to overclock very much since cooling is limited and Bios's generally aren't unlocked. Check your bios to see what options are available and we can go from there.
Did you check what options are changeable in your bios? Try hitting del or f1 when the computer is booting up to get into it and see if you can change any settings.
