1 - 2 of 2 Posts
If you are using a single IDE cable (capable of ATA133) with a single ATA133 device, it should default to the motherboards highest ATA setting.
If you are using a dual device cable, the IDE port will default to the lowest speed of the two devices.
1 - 2 of 2 Posts
