1 - 13 of 13 Posts
Linux Guru
Originally Posted by Megalomaniac
I got this ATA converter that changes a ATA 100 or ATA 130 to a SATA 150...The only problem is it doesn't work...or I don't know how to work it...
Is the SATA enabled in your bios and have you ran the SATA installation CD that came with your mobo?
This is the description from the MoBo site:
Serial ATA 150
Serial ATA is an evolutionary replacement for the Parallel ATA storage interface. This new high-speed interface burst data transfer rate up to 150 Mbytes/sec and more flexible power tolerances, cables can be smaller and more efficient.
And here is a link the the converter site http://www.abit-usa.com/technology/serillel_new.php
Linux Guru
Serial ATA 150
It looks like you are using an ABIT mobo, and on their mobos there is an enable/disable SATA option in BIOS, make sure that it is set to enable.
And again in the mobo installation packet there is a floopy boot disk labeled SATA Installation, run that disk.
do you have a working windows installation? If you do you might be able to get what you need off the internet, otherwise, yes you have to use the disk.
Linux Guru
Do I have to use the disk? I didn't install a floppy drive...I can if I have to
The disk contains valuable configuration information for your SATA, I recommend installing the floppy and running the disk.
It came with a CD
....I assume I still need the floppy...
you assume correctly... there is not a way to my knowledge to install without one... hehe... floppy became defunct and SATA brang it back... but it is still necessary because I never found a way to do a true reformat with fdisking...
If I get this working I don't have to reformat the HD do I?
Well I wasn't sure your exact situation. Is windows by any chance already installed on the hard drive. Perhaps just enabling the SATA in the BIOS and hooking up the drive with a windows install will cut it. Perhaps not though. I always have a hellacious time installing new hardware. Just try enabling the SATA in the BIOS and hooking the drive to sata... post you results
1 - 13 of 13 Posts
