1 - 5 of 5 Posts
hey, i have overclocked my athlon +4000 from 2.1 to 2.65 with a stock heatsink but with 5 case fans. does anyone know of a safe limit for me to overclock to???????
thanx
Discussion Starter · #2 ·
btw core temp says the system is running at 33C idle and 48 with a load but i have offset the temp by +10 degrees. if anyone knows weather these temps will be accurate or are ok the help would be very helpfull also.
thanx
Efficiencycionado
get a good cpu cooler 1st before you toy with the voltage. you might end up frying it.
1 - 5 of 5 Posts
