1 - 2 of 2 Posts
My COM is
Athlon 64 3200+ NewCastle socket 754
DFI Lanparty nF3 250 UT
CoolerMaster eXtreme 380W Dual
I've OCed it in to 2.4 GHz and pass the OCCT stability test
FSB: 240 MHz
LDT/FSB :x3
CPU/FSB:x10
DDR/FSB : 5/6
CPU VID control at 1.525
CPU VID Special Control at: Auto
-----> CPU voltage at BIOS when I start my PC is 1.54
is there any probs with my Voltage setting ?? PLease help me to find the suitable Voltage for my Comp ...thanks a lot
by the way...what is the limit voltage of my CPU ??
thanks for answer !!
Originally Posted by tranphuloc
My COM is
FSB: 240 MHz
LDT/FSB :x3
CPU/FSB:x10
DDR/FSB : 5/6
Sometimes the voltage doesn't hover quite at what you set it to. Max voltage is probably well over 1.6, heats much more important.
You should be able to monitor heat of the CPU (using a provided DFI program) and as long as that's under 60-ish (I would stay under 60°C) the voltage shouldn't be a problem.
-Nik
1 - 2 of 2 Posts
