Also, bump, so more ppl would see and it proly gets pinned in the AMD section
Thanks!
Thanks!
My 260 managed to get to 3.7 @1.55v
Probably the cheapest Kingston i guess?
CPU temp is measured at the socket, and by a sensor.Originally Posted by Athorne
Just tested with LinX @3300MHz, max temp 59, core temp - not over 45. Do you think I can go more?
BTW my cpu multiplier cant go over 15, and its 15 by default.
EDIT: Second test: @3460Mhz - max core temp 48C, max cpu temp 60C, 7mins without errors. Do you think thats safe? And what is actually the difference between the CPU temp and the Core temp? Im monitoring the cpu temp from EasyTune6.
No, the stock coolers of Athlons are a joke. You need heatpipes. At least 6 total (3 U-shaped).Originally Posted by Athorne
Well I actually tested it in BF3 with 3.4GHz and there was no difference, atleast not big enough to make it playable, HD 6850 was still at max 35-40% usage. I think I need over 3.6GHz to make it playable with 80%+ gpu usage, but I dont think this is possible with stock cooler.
HiOriginally Posted by cadogen
I did it and here's my results. [But NB confusion]. someone kindly help.
ref. clock : 247
NB multiplier : 9 couldn't get a 10 so 2500-2800 wasn't achievable. this is my doubt
ram multiplier : 533
SPD applied set : 609frequency table {8,8,8,22,30}
_________________________________
so did I miss anything any info ... need reply please help. was this overclock any good?![]()
No to all 5 questionsOriginally Posted by cadogen
New results
5 questions
I was doing this before reading the reply> So please update me on this one. I will read and make corrections from the above reply
I was also thinking about the voltage level up but the range was confusing!
1.Should I go for 1.55 V and above. 1.6V or above is always error reported by the bios
2. By the way which all things should I disable? I already did turn off cool n quite.
3. meanwhile HDD SMART gave me some error and had to turn it off [god knows what]
4. Sometimes after applying settings I can boot and log in to windows. but when I restart it from there bios wont even turn on. then i have to RESET it on and bios will show overclock error. then i will do some minor tweaks and repeat the cycle. this is sick. is the some 'cool n quite' sort of thing doing the voltage regulation? [well now its OK but i think I could have raised the bar a bit if this wasn't happening
5. Last one. Is it ok for the HW MONITOR tool to hang a bit. whenever i open it or close it it slows the whole system for a while and then goes back to normal. everything else is stable.
HAD TO COMPROMISE ON NB multiplier its 8 [8 x 249 = 1992] and ram is at 400 with 7,7,7,20,27 spd values
That must have been wrongly written. No mobo has 512. Maybe they set it to 667 (which is stock 1333), and that what they meant.. I don't know.
